Need some help on finding the correct tire size
Discussion in 'Wheels & Tires' started by SJginger, Aug 30, 2011.
  1. Aug 30, 2011 at 5:45 PM
    SJginger
    SJginger [OP] Well-Known Member
    Jerry
    South Jersey
    08 tacoma trd sport, stock for right now!!!
    im new to off road world....i have an 08 trd sport with 17" wheels. i am getting a 3" lift in about a month my question to everybody is what size tires should i run i do plan on wheeling. if anyone could help it would be awesome
  2. Aug 30, 2011 at 5:46 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Are you getting new rims? Okay with running wheel spacers? Okay with trimming plastic and possibly chopping your cab mounts?
  3. Aug 30, 2011 at 5:47 PM
    SJginger
    Jerry
    South Jersey
    in the furture ill get new rims. if spacer are needed then sure and cutting plastic sure and by cab mounts what do you mean?
  4. Aug 30, 2011 at 5:49 PM
    SJginger
    Jerry
    South Jersey
    is it possible to run 31" on the stock rim without wheel spacers or cutting anything?
  5. Aug 30, 2011 at 5:50 PM
    KPT
    09 Prerunner
    :conused: The truck comes stock with 31s.
    You can run 32s with no issues, even with no lift.
  6. Aug 30, 2011 at 5:54 PM
    SJginger
    Jerry
    South Jersey
    ok cool im assuming i can run 32" on the stock rim correct?
  7. Aug 30, 2011 at 5:54 PM
    KPT
    09 Prerunner
    Yes sir.
  8. Aug 30, 2011 at 5:58 PM
    SJginger
    Jerry
    South Jersey
    thanks for all the help. u have any suggestion on what i should run as in metic size and brand???
  9. Aug 30, 2011 at 5:59 PM
    KPT
    09 Prerunner
    265/70/17, and as for the brand, it's really up to you. Popular AT tires on here include BFG ats, Goodyear duratracs, nitto TGs, and hankook dynapros.
  10. Aug 30, 2011 at 6:06 PM
    SJginger
    Jerry
    South Jersey
    ok thanks again for help man
  11. Aug 30, 2011 at 6:16 PM
    doons
    doons Active Member
    KANADIA
    2011 V6 4X4
    what do you guys think of mickey thompsons mtzs
  12. Aug 30, 2011 at 6:19 PM
    KPT
    09 Prerunner
    They are very aggressive. A friend of mine had some and they were hard to balance and wore poorly, but did very well off road.
  13. Aug 30, 2011 at 6:20 PM
    KPT
    09 Prerunner
    You are welcome.
  14. Aug 30, 2011 at 6:42 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    You could probably run 275/70R17 with no issues what so ever or so I've heard. I'm actually about to put 275/70R17 Wrangler AT/S's on mine. They are 32.4 inch tires. The only thing is there are not a lot of options with this tire size.
  15. Aug 30, 2011 at 7:07 PM
    KPT
    09 Prerunner
    Please report back as to whether you have any rubbing. Not many folks run 275s so I never know what to tell people who ask about them.
  16. Aug 31, 2011 at 3:41 PM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    Will do.
