need some help on this lol
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma08brandon87, Jan 4, 2014.
Thread Status:
Not open for further replies.
  1. Jan 4, 2014 at 7:16 PM
    tacoma08brandon87
    tacoma08brandon87 [OP] Well-Known Member
    brandon
    El Paso Texas
    TRD
    Looking to buy 285 70 16 do you waste more gas I have 2008 tacoma 2w
  2. Jan 4, 2014 at 7:21 PM
    TugBoatTrash
    TugBoatTrash Face first!! Hammer down!!!
    Bob
    E. Freetown MA
    15 DC Tundra SR5
    Do dents and scratches count?
    umm… I don't think using more gas is a waste, if the trade off is you get what you want out of your truck.
  3. Jan 4, 2014 at 7:23 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    285/70-16 is not a common size. TireRack found nothing. Discount Tire Direct returned just one tire - Nitto Trail Grappler M/T in load range E. You'll lose about 1 mpg just because this LT tire is ~20 lb heavier than OEM. In theory if you found such a tire in Standard Load (SL) or P-metric, you won't have a noticeable loss in fuel economy.
  4. Jan 4, 2014 at 7:27 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    The real catch here is to account for the larger tire size... You will lose MPGs with the heavier tires but remember when doing calculations to adjust the miles based on the tires.. With bigger tires the OD will read less than the true amount...
    CANADIAN EDIT: loose to lose... :boink:
  5. Jan 4, 2014 at 7:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    lose
    and we're talking 5%
  6. Jan 4, 2014 at 7:39 PM
    KenLyns
    Belly of the Beast
    5% of 20 mpg is 1 mpg, but the difference between 32" and 31" tires is actually about 3%. :p
  7. Jan 4, 2014 at 8:40 PM
    NewRider
    Travis
    '87 4runner
    Thank you for the correction... Stupid auto correct on the iPad along with my bad spelling and that's what I get..
    And ya, it may only be 3-5% but when people start bitchin when they drop to say 13mpg from 16 with new tires... Plus 1mpg over a years time can really add up if mileage is what you're concerned about... Personally I plan to run two set of wheels to counteract the worse mileage until I can truly afford to just a run the off road type tires constantly
Thread Status:
