need some help... spiral cable
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rberumen2, Jun 14, 2011.
  1. Jun 14, 2011 at 5:41 AM
    rberumen2
    rberumen2 [OP] Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    apparently i only have the gold plan warranty so it doesn't cover the one thing i need. I wasted 120 for the dealer to tell me that i need a new spiral cable to turn my airbag light off. if i paid for them to do it, they would charge 600 bucks
    does anyone know where i can get this?
  2. Jun 14, 2011 at 7:32 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    http://www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=214001&chapter=&sectionids=3,2413&groupid=10051&subgroupid=20134&componentid=60248&make=34&model=Tacoma&year=2006&catalogid=1&displayCatalogid=0
    I couldn't find one listed at autozone, napaonline, or advance auto.
    Disconnect neg battery cable, wait 15 min, remove screws on back of steering wheel, remove airbag and disconnect it's cable, disconnect/remove spiral cable/clockspring, reverse order for install(minus wait time).
    Do not let anything touch the bare connector on the airbag. Best to store it away/outside the truck.
  3. Jun 14, 2011 at 5:36 PM
    drcaleb
    drcaleb member
    Vermont
    06 Access 4x4 base model
    intermittent wipers, 400w inverter, heated mirrors, illuminated 4wd switch, auxillary reverse lights, oba
    it is as easy as skytower says. only thing he forgot was that you need to remove steering wheel (19mm i think) and you may need a wheel puller for that. mine popped right off without it. make sure when you put it back on that it is straight relative to the wheels.
    https://www.1sttoyotaparts.com/oempartscat.html
    84306-0e010 spiral w/jbl audio $217
    84306-04080 spiral regular $198
