need some help with an idea
Discussion in 'Lighting' started by esimmons, Jun 15, 2011.
  1. Jun 15, 2011 at 10:29 PM
    esimmons
    esimmons [OP] Well-Known Member
    Evan
    Kannapolis, NC
    2007 PreRunner
    Nerf Bars, Bull Bar
    ok so i have an idea that i believe will be pretty sweet mod
    the idea is to create a small fiberglass "pocket" right behind the Toyota symbol. then i want to put a small light behind the Toyota symbol and have it shining back on the pocket so it will give a nice ambient glow. i do not want it to be so bright that it is like a head light just bright enough to basically glow.
    however i do need some help with the wiring. so basically what i need is to run a light (something no bigger than lets say a trailer light and possibly even as small as a led. that part im going to have to test) from the cab to the front of my truck. i need to know if i need a relay or anything like that. i can go from a in switch to the light just need to know how to do the fuse/power/relay part.
    any ideas?
  2. Jun 16, 2011 at 7:18 AM
    esimmons
    Evan
    Kannapolis, NC
    2007 PreRunner
    Nerf Bars, Bull Bar
    edited with mod detail
  3. Jun 16, 2011 at 7:23 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i would say look into getting a led strip of your choice check out superbrightleds.com that got all manner of parts to choose from. i would look into a really low power unit so hopefully its not stupidly bright like a headlight as you said.. either that or just get one medium sized bulb and plug in the back and have the housing you make disperse the light as evenly as possible and maybe use filters to get the color you want and to limit some of the light output? i dunno just ideas
  4. Jun 16, 2011 at 7:30 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    If you do a small LED strip, you do not need a relay. As long as the amperage of the LED does not exceed the rated amperage of the switch, you can just wire the switch in series with the LED itself.
    I'd recommend these.
    They are a cuttable LED strip with a sticky back that are very bright. Just google "cuttable LED strips" and you should be able to find a place to buy them room. They are usually 12v.
  5. Jun 16, 2011 at 7:32 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    BTW, this isn't a new idea.
  6. Jun 16, 2011 at 7:35 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    That would be exactly opposite of what you should do, you need a switch with an amperage rating higher than that of the LED, not lower. The switch is not a power-consuming device, it must be selected with the circuits amperage in mind.
  7. Jun 16, 2011 at 7:40 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :D
  8. Jun 17, 2011 at 7:36 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    agree...LED's draw such little current you shouldn't need a relay. I would use a relay for any type of bulb, and I don't recommend tapping straight off of a wire to power it. Check out my electrical basics thread, i talk all about wire sizes and basic circuit design (link in signature).
  9. Aug 11, 2011 at 8:02 PM
    esimmons
    Evan
    Kannapolis, NC
    2007 PreRunner
    Nerf Bars, Bull Bar
