Need some help with my King's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlastic, Oct 10, 2015.
  1. Oct 10, 2015 at 8:59 AM
    jlastic
    jlastic [OP] Well-Known Member
    Jordan
    Orange County
    15 DCSB 6speed 4x4
    -Kings all around -spintech 9000 -2 Phoenix gold 12s in the bench -Kicker 1200 amp/ bass nob -Toughlight leds -50" radius (MCM Fab roof mounts -30" straight in the grill -2 hood pods (cbi brackets) -diff drop -1" blocks in the rear -shovel, axe, hi-lift and 2 20mm Ammo cans filled with recovery gear bolted to the bed rails. -led glow interior lights -8500K HIDs headlights and fogs -plastiderped emblems and grille -K&N cold air Near future mods...... -Doug Thorley Long tubes -TC uca's -aero 2525xl
    Hey guys so I'm holding off on UCA's for a few months and after dropping my truck off for 12K scheduled maintenance, the alignment is at spec and I've still got some negative camber. I'm running king 2.5s and I've got 8 threads showing on both the front driver and passenger sides. Would screwing the shock down a few threads mitigate my problem? also running BFG a/t KO2's 285/75r16 4runner steelies on a 1.5 spacers
  2. Oct 10, 2015 at 9:16 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    What are your alignment specs? Altering the height of the suspension is going to change ALL of the parameters of the alignment. If you have negative camber than lifting a little might "fix" that issue, but throw off your caster and prevent it from being in spec.
    They can't fix the camber issue? Have you considered lowering the coilovers slightly to get a proper alignment until you get new UCA's?
