NEED SOME HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ksmoove757, Sep 24, 2013.
  1. Sep 24, 2013 at 6:32 PM
    ksmoove757
    ksmoove757 [OP] Well-Known Member
    Kenneth
    VA BEACH
    2012 Tacoma Sport 4x4
    I have a 2012 4x4 Tacoma sport doublecab with bilsteins 5100s all around, the front set at the highest and a 1 inch block in the rear. I currently run 285 70r17 Terra grapplers with the stock tacoma sport rims with no rubbing at all. I'm planning to get 17 inch rims, and I'm wondering what offset do I need for a perfect fit?
    Thanks,
  2. Sep 24, 2013 at 6:37 PM
    ksmoove757
    Kenneth
    VA BEACH
    forgot to say i have 1 inch wheel spacers also.
  3. Sep 24, 2013 at 6:39 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Get rid of your wheel spacers and get wheels that have a -12mm offset with a 4.5" backspacing and you will be golden.
  4. Sep 24, 2013 at 6:50 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    X2 thats what mine are & I'm running the same size tires as you op with no rubbing.
  5. Sep 26, 2013 at 4:38 AM
    ksmoove757
    Kenneth
    VA BEACH
    Thanks for the info guys, you think buying aftermarket rims will get rid of the little vibrations I get from running my stock rims with spacers?
