Need some immediate help: Which wire controls the brights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by veg hed, Oct 23, 2015.
  1. Oct 23, 2015 at 12:20 PM
    veg hed
    veg hed [OP] Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    image.jpg Can't find my test light and I'm deep into this project. I'm hooking up my spot lights to come on with my brights.
    I have the following wires:
    Red/Blue Stripe
    Red/Green Stripe
    Red/White Stripe (could be yellow, it's a little dirty)
    Also, it's on the drivers side if that helps.
  2. Oct 23, 2015 at 12:27 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    white is always for ground on our trucks
    no need to overthink things, just get a scrap wire and touch 12v + to one of the side pins to see which is high and which is low beam, then you know
  3. Oct 23, 2015 at 1:39 PM
    veg hed
    Utah
    It was Red/Green
  4. Oct 23, 2015 at 2:12 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Are you using a relay?
  5. Oct 23, 2015 at 5:11 PM
    veg hed
    Utah
    Yes
  6. Oct 23, 2015 at 5:29 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Not sure how you are planning to wire the spot lites, but you should consult a wiring diagram for your specific truck before splicing into the harness.
    According to my 1999 FSM, when the HL relay is energized (by turning on the HL sw) power goes thru a fuse and to the HL (with 2 filaments) via a Red/Blue wire. From there 2 wires (Red/green and Red/yellow) go to the HL switch which selectively completes a ground. One wire is for the low-beam, and the other is for the high-beam. So both 'return' wires should be 'hot' with the HL on, but only the low-beam is on since its 'return' wire is now grounded thru the switch. When the hi-beam (brights) is selected, the grounding is switched to the hi-beam 'return' wire.
    Peculiar way for Toyota to do it. I hope I'm making sense.
  7. Oct 23, 2015 at 7:25 PM
    NightProwler
    Harlan
    Maricopa, Az
    Yep that's why I asked if he was using a relay. Our trucks high beams are negatively switched. The easiest way to do it, is to wire the ground AND activation switch to the low AND high beam wires. Then it will work properly. I can't remember what pin goes where but it's something like this:
    30 battery positive
    87 to aux light
    85 to low beam (should be a negative)
    86 to high beam(should be activation wire)
    85&86 might need to be switched depending on witch one is ground.. I can't remember atm.
  8. Oct 23, 2015 at 7:56 PM
    veg hed
    Utah
    Thanks for the input guys...This might explain why when I first spliced into the Red/Blue wire, which on the diagram I tracked down stated it was for the highs, it didn't work. But when I switched it to Red/Green the lights come one with the brights switch when the toggle is switched to on.
