Need some info on 5100's
Discussion in 'Suspension' started by senna, Jul 27, 2009.
  1. Jul 27, 2009 at 2:38 PM
    senna
    senna [OP] Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    So if run 5100's in the "0" position and use OME 885 springs, this will give 2" of lift correct?
    the reason for using the OME spring's is to avoid pre loading the stock spring's, and maintaining a more compliant spring
    Do the 5100's have more travel than stock bilstein,s?
    Or are we actually loosing shock travel with each step up in lift?
    "0" no loss in shock travel
    ".85" = .85 loss of shock travel
    "1.75" = 1.75 loss in shock travel
    "2.5" = 2.5 loss in shock travel
    And by using OME 885 set at "0" on the 5100's I am assuming give me 2" of lift I will loose 2" of travel
    Do the OME N-140s shocks have more travel?
    The way I see it if I am going to lift my truck I want to gain travel if possible, but I certainly do not want to loose travel.
    Am I on the right track here?
  2. Jul 27, 2009 at 2:42 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Yes you are on the right track... You do lose travel but not enough to worry about.
    To gain travel you will have to go with the Toytec coilovers
  3. Jul 27, 2009 at 2:43 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    when lifting the truck 3" you will lose 3" of downtravel but gain it in uptravel.
    yes you are on the right track.
    and yes you would keep the shock at 0 and get your 2" of lift from the spring.
    if you want to gain travel in both directions and get lift look into new spindles (2wd) or long travel
  4. Jul 27, 2009 at 2:44 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    You won't really "gain" or "loose" travel either way. When you preload you trade down travel for uptravel. When you get phased struts and progressive coils, you don't gain travel, it just changes how your travel is spent.
  5. Jul 27, 2009 at 2:45 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You do not loose travel.. You will loose some droop, but that is about it.
  6. Jul 27, 2009 at 2:45 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    for a daily driver it wont really be that big a deal, the majority of the trucks here have a 3" coil lift (coilovers) or lift using the billys.
    so you really cant go wrong either way
  7. Jul 27, 2009 at 2:51 PM
    senna
    San Jose CA.
    If the toytec C/O's are based on 5100's how is it any different?
    Thanks for your input
    If you or I lifted 3" we are essentially extending the shock that much, so seams to me if anything we would gain down travel, being as we already extended the shock 3" .
    Hope I am making sense.:eek:
  8. Jul 27, 2009 at 3:01 PM
    senna
    San Jose CA.
    this makes some sense, thanks
    By droop you mean if you preload a spring you essentially increase the rate of the sring,right?
    I want and do off road, and this is why I want to understand.
    Thank for commenting.
  9. Jul 27, 2009 at 3:03 PM
    senna
    San Jose CA.
    One question still remains, do the 5100,s have more travel than stock bilstein's?
  10. Jul 27, 2009 at 3:11 PM
    SC4333
    Grant
    FL
    Droop is the downward cycling of your suspension from its natural state (all four sitting on the ground).
    By using 5100s or coilovers to achieve lift you are using a higher spring rate, whether it is by utilizing a preloaded spring (5100s w/ stock springs at say, 2.5) or using a longer length spring like the OME springs. In doing so, your truck will loose some of its droop because the suspension is holding your truck higher off the ground than it previously was.
    The only way to eliminate this is with a spindle setup(approx 4.5 inches of lift), or drop bracket (6 inch lift). OR you could also go with aftermarket UCAs and extended travel coilovers like the ICONs for example. The loss of droop really isn't much of a big deal unless you are going to be hauling ass off road.
  11. Jul 27, 2009 at 3:25 PM
    senna
    San Jose CA.
    Ok I was thinking more of a sag instead of "droop"
    But, wouldn't the OME's vs preloading the stock springs have a better spring rate?:confused:
  12. Jul 27, 2009 at 3:45 PM
    drew02a
    San Antonio, TX
    Probably not, because they're rate is designed specifically to go hand in hand with OME struts.
  13. Jul 27, 2009 at 4:24 PM
    senna
    San Jose CA.
    Aren't ome's a longer spring, thus achieving the lift without as much spring rate vs a preloaded stock spring?
    Isn't a shorter preloaded srping going to coil bind much sooner than a longer spring.
    If you pre load a stock spring it has a higher spring rate in a shorter captured height.i.e moving the lower plate up on the shock.
    Where on the longer spring the lower plate is on the lowest setting, giving more build up to the same spring rate.
    Am I making any sense.
  14. Jul 27, 2009 at 4:38 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Toytec Coilovers use 5100s. They just have adjustable bottom mount for the spring.
  15. Jul 27, 2009 at 4:47 PM
    senna
    San Jose CA.
    Aren't all front 5100's adj? the toytec might be more conveinent and in smaller increments but the end result is the same, you are pre loading the spring, thus increasing spring rate and raising the vehicle and in the end loosing spring travel?
    I am not saying any body is wrong here, I just want to do what is best, not what is most popular.:)
    I am off to do a mountain bike ride and mull all this over.
  16. Jul 27, 2009 at 4:58 PM
    drew02a
    San Antonio, TX
    There are several other threads on this site that discuss the paring of OMe coils with Bilstein 5100s. I suggest searching for them. There's on in particular where Chris4x4 weighted in. Find it
  17. Jul 27, 2009 at 6:16 PM
    senna
    San Jose CA.
    Thanks I'll look for that.
  18. Jul 27, 2009 at 6:17 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    For $700, go with (4) OME shocks, (2) 885 OME springs and a 1.5 TSB AAL.
    That should give you 2-2.5" in the front and 1.5" in the back. If you already have the TSB, this should level you out and give you about 2.5" all the way around. Plus a softer ride than stock bilsteins.
    I've read the 885's wear out sooner than the stock coils on 5100's but that is a fair tradeoff.
    This is the route I am leaning toward. Where I hesitate is that I don't think I'll be off-road much at all. Do I need all of that or can I just get front 5100's set at 2.5" and an AAL for about $300.
  19. Jul 27, 2009 at 6:21 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    :thumbsup: yeah thats what i just bought...i was in the same boat about not off roading that much but my father taught me that if im going to do something that i should do it right the first time...not saying theres anything wrong with 5100s but i didnt want to buy something and wish i had spent a little more and go what i really wanted.
  20. Jul 27, 2009 at 6:30 PM
    senna
    San Jose CA.
    Well, I already ordered the 5100's, they will be here tomarrow, I called down south motorsports and they said if I do not open the box I can return them without penalty, I eat return shipping. excellent, if I go that route.
    so I just have to decide which shock I want to use.
