Need some info on driveline oils
Discussion in 'Technical Chat' started by Hgkilla, Apr 8, 2012.
  1. Apr 8, 2012 at 5:04 PM
    Hgkilla
    Hgkilla [OP] Little Brown Pool Boy
    Cody
    Central Texas/Gulf Coast
    06 Access Cab Sport 4x4 6sp
    Yeah its in the making but its still a taco
    Ok so i want to change all my driveline oil front diff,transfer, gear oil, rear diff but i have never done it on the taco before but can i get the weights and additives i need to do all of this ? i heard redline is legit
  2. Apr 8, 2012 at 5:16 PM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
    I replaced my front diff, rear diff and transfer case fluid with AMSOIL 75W90 Severe Gear Synthetic Oil. I didn't use any additives, since my 2010 has an open diff - the limited slip is electronic...brakes and throttle. If yours has a limited slip diff, you may need to put in some additive in the rear diff only. It's hit or miss with the chattering around corners with synthetic gear oil.
    I have also hear good things about Mobil 1 synthetic gear oil too...
  3. Apr 8, 2012 at 5:19 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    Here is for the rear diff:
    https://sites.google.com/site/tacomamaintenance/limited-slip-differential-oil
    Here is for the others:
    http://www.tacomaworld.com/forum/2n...ront-diff-transfer-case-oil-change-howto.html
    If you have a mechanical LSD (limited slip diff), make sure you use DINO (not synthetic) gear oil with the LSD additive in your rear diff. Even a synthetic oil with the additive will cause too much slipping and chirping.
    Make sure the weight is correct, 75w-90
    I didn't see a difference with running different gear oil in my truck. I've ran Royal Purple (syn), Mobil 1(syn), and valvoline (dino) and I didn't see a difference with my MPGS, or the amount of wear really when I changed the fluid (like how worn down the fluid was). Just run whats available and what you can afford.
  4. Apr 8, 2012 at 5:50 PM
    Hgkilla
    Cody
    Ok what about my gear box oil cause i got the 6 spd
  5. Apr 8, 2012 at 5:57 PM
    Bishop2Queens6
    SoCal
    2009 DCSB MGM
