Need some installation advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFRNDAN, Mar 28, 2011.
  1. Mar 28, 2011 at 10:01 PM
    FFRNDAN
    FFRNDAN [OP] Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    I'm working on installing a Smart Siren in my 2009 Acess Cab. This is a siren/emergency lighting control unit i use for FF/EMS. My issue is mounting the brain in a good spot. Its about 6"x6"x3.5", and has quite a few wiring connections on one side. Here's an ad for reference, the control head is getting mounted to the center console.
    http://www.lonestarpse.com/federal-signal-smart-siren-ss2000sm-sd.html
    right now I threw it in the truck where the factory inverter would go, if I had one, but its an awkward fit, and is difficult to run wiring to/from and connect to the unit. My requirements are: Somewhere dry, Somewhat easily accessible, and easy to run wires to.
    I was thinking about buying a battery box to mount it under the hood, similar to this: http://www.google.com/products/cata...=X&ei=s2GRTZ_HOsKZ0QGz_6HkDg&ved=0CD0Q8wIwAg#
    To mount under the hood, but I wanted to run it by TW to see if there are any bright ideas. Thanks! Also sorry for the long post.
  2. Mar 29, 2011 at 8:48 AM
    FFRNDAN
    Dan
    Edinburg, Oh
    Bump for the day crowd. I'm about to go out and see if it will fit under the seat.
