Need some lift answer before I buy my lift
Discussion in 'Suspension' started by rsincavage85, Apr 14, 2010.
  1. Apr 14, 2010 at 11:34 AM
    rsincavage85
    rsincavage85 [OP] Well-Known Member
    Rick
    Plains Twp. Pa.
    Super White SR5
    Ok I think I found what I am going to do with my lift. Just concerned about the famous taco lean discussed inhere. Plan on buying AAL and 5100 for the front set to .85 or 1.75 not sure yet still need to measure the truck now sitting on level surface. Looks to sit really close to level now though. That I will figure out later and can go higher with blocks for the rear if need be. Question is would I have an issue with the lean or not? Seems like some do some don't.
    Thanks for the honesty
  2. Apr 14, 2010 at 12:37 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you are using the Bilstein 5100s with your factory coils, then you should not have any lean issues.
  3. Apr 16, 2010 at 9:20 PM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    Alright I have a question now too. If I were to get 5100's for the front, I can set them to 2.5 using stock everything? Including coils? Thanks
  4. Apr 17, 2010 at 8:56 AM
    ZonKs
    ZonKs Can speak french in Russian.
    Glendale, CA
    =p
    Not exactly true in all cases. I have the 5100's / factory coils with the toytec spacer on the drivers side. I STILL have a slight lean. Also i have my 5100's set at .85 with the spring TSB. I have a very slight rake.
