Need Some Maintenance Tips
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jams, May 31, 2013.
  1. May 31, 2013 at 4:25 PM
    Jams
    Jams [OP] New Member
    Gulfport MS
    2001 Tacoma Double Cab V6
    I have a 2001 Tacoma Double Cab V6. Bought in 2003 with 50k on it and I now have 161k.
    I haven't done much as far as maintenance on this thing other than changing the oil religiously and some brake jobs. It still runs great, but I know I should have had the timing belt changed out many miles ago.
    Just wondering what else should be done to keep it happy. I plan on getting all the belts changed out, but have read about changing the water pump while they're in there. I've also read to just make sure to keep the transmission fluid full and never do the flush.
    Any help for this board newbie would be greatly appreciated!
  2. May 31, 2013 at 4:35 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    http://www.tacomaworld.com/forum/1s...y-how-thread-compiled-list-helpful-links.html Everything that needs maintained is is in here. Greasing driveline, coolant flush(when timing belt and water pump is done since you need to do that anyhow). Bleed brake system and replace with new fluid. Plugs and wires if they havnt been done, transmission drain and fills( needs to be done) a couple will do and then regulary. I would drain diffs and replace w/synthetic gear oil and transfer case if 4x4. Synthetics for all other than tranny. Toyota type 4 or what your dipstick says.
  3. Jun 1, 2013 at 6:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Also...
    Replace the thermostat at the same time you replace the water pump.
    Fuel filter
  4. Jun 1, 2013 at 7:05 AM
    TACO TX
    Kelly
    Denison ,Texas
    Toyota fuel filter is suppose to be lifetime part but i dont buy it so i replaced w/Wix filter. I did mine because i was having issues running like shit. After replacement and no fix it finally threw a code and it was a fouled plug.
