Need some more height on the 2011 Tacoma SR5.. Advice?
Discussion in 'Suspension' started by barcapopo, Apr 19, 2013.
  1. Apr 19, 2013 at 10:50 AM
    barcapopo
    barcapopo [OP] Active Member
    Vancouver / Point Roberts
    SR5 Tacoma
    Hey guys.. I have a 2011 Tacoma Sr5, I'm looking to get a little more height on my truck. Does not feel like it has the right truck height. Thinking of getting a 3" lift. It looks like right now my front end is lower than the back, id like to get it evened out. I'm not familiar with what would be the best options, looking for some suggestions on what to get. I won't be doing any off roading, it's simply for asthetics. Thanks!!
  2. Apr 19, 2013 at 10:53 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    5 lug or 6?
  3. Apr 19, 2013 at 10:56 AM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    spacers will be your cheapest option if you're not gonna be offroading
  4. Apr 19, 2013 at 11:26 AM
    barcapopo
    SR5 Tacoma
  5. Apr 19, 2013 at 11:28 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Bilstien 5100 shocks from downsouth motorsports......still maintain decent ride, lift up to 2.5" safer than spacers.
    Talk to Sonny or Micah
  6. Apr 19, 2013 at 11:31 AM
    barcapopo
    SR5 Tacoma
    Adjustable shocks?
  7. Apr 19, 2013 at 11:39 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    They have settings for 0.85" 1.75" 2.5" or zero lift.
    U gotta have them dissasembled to raise/lower them tho.....they are not on the fly adjustable like the more expensive coilovers, but they do the job for some people just fine.....I can't complain with eibach coils and 5100s
  8. Apr 19, 2013 at 11:44 AM
    barcapopo
    SR5 Tacoma
    Ya I would just get the height I like and leave them be. So what would I need to get this done? Just 4 5100's? Sorry my ignorance, not familiar with suspensions etc.. Is it pretty labour intensive to get installed?
  9. Apr 19, 2013 at 11:45 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    2 5100s are all that's "needed"
    The fronts provide lift, the rears don't lift but provide a good compliment to the fronts ride.
    Don't forget to get an alignment
  10. Apr 19, 2013 at 12:03 PM
    barcapopo
    SR5 Tacoma
    by lifting the fronts the backs will raise slightly?
  11. Apr 19, 2013 at 12:12 PM
    barcapopo
    SR5 Tacoma
    If I have the fronts at 2.5" lift would front look higher than back? If so, what would be option for backs?
  12. Apr 19, 2013 at 12:48 PM
    barcapopo
    SR5 Tacoma
    Vehicle also came stock with 16" rims. Would there be clerance to go to larger tires rims?
  13. Apr 19, 2013 at 1:07 PM
    PELLEY
    PELLEY Well-Known Member
    MY 2 cents... Don't get too caught up on looks. The 5100's are a good entry level shock but don't go max, I would go 1.5" and run it like that. You might have a slight ass-high look, but what is more important? maintain-ability and ride or looks? If you keep them at 1.5," the spring rate won't change too much, and the truck will still ride great. You will also keep your axels at a reasonable angle, keeping the wear and tear factor down. I know the 2nd gens have improved axel angles and don't require the diff drop, but that doesn't mean to just crank um up. Then if you want to go higher, just get bigger tires and gain a few inches that way. There is a tone of info in the 2nd gen sticky section on what tires and rims fit, get the biggest ones you are happy with. Doing the body mount chop is easy, and will be cheap for any shop to do, BAMF makes a good bracket for that. Then spend your time and money on fun mods!!!
  14. Apr 19, 2013 at 1:21 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    x2 But I would also recommend replacing the rear shocks w bilsteins. The ride will be much better if you do especially since you would be changing out the fronts
  15. Apr 19, 2013 at 1:25 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    2011 AC with 5100s all around w/ front set at 1.75" using stock coils and with the TSB (4-leaf) springs in the rear. I was about 1/4" higher in the back until the leafs settled and now I'm slightly (1/4~) higher in the front. These are 17" rims with 32" tires and I get light rubbing on the mud flaps at full crank. This is a heavy cap (~225lbs) so I would probably still be a bit higher in the rear if I was running topless.
  16. Apr 19, 2013 at 1:27 PM
    barcapopo
    SR5 Tacoma
  17. Apr 19, 2013 at 1:32 PM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Yup. They definitely improved the ride by putting them all the way around too.
  18. Apr 19, 2013 at 1:51 PM
    PELLEY
    I agree with this as well!!
