Need some new headlights.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by berry79, Sep 16, 2015.
  1. Sep 16, 2015 at 5:08 AM
    berry79
    berry79 [OP] Well-Known Member
    Homestead, FL
    08 DBL Cab LB
  2. Sep 16, 2015 at 5:24 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    other brands ? OEM only
    these aftermarket lights do not, and never will, pass photometric requirements
    they have beam artifacts because the careful ($$$$$$$) engineering to make a proper
    reflector assembly and do the testing and pass photometrics is not done.
  3. Sep 16, 2015 at 5:28 AM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro
    You should verify if they fall into the extended warranty or not. I just got mine replaced for free by the dealership a few months ago.
  4. Sep 16, 2015 at 5:40 AM
    berry79
    Homestead, FL
    08 DBL Cab LB
    Never even though about that. Might give that a try first. Thanks
  5. Sep 16, 2015 at 10:23 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The only headlights I would run are OEM or CAPA Certified aftermarket. Anything else has likely skipped on optics engineering and testing to produce a quality reflector.
    CAPA certified means it has been tested by procedures from ATSM and SAE to be OEM equivalent in terms of performance and construction. They do cost more, for good reason, but are cheaper than OEM. I have purchased non-CAPA headlights and CAPA headlights, there is a significant difference in build quality, light aiming and correct light projection.
    Like this: http://www.amazon.com/Toyota-Tacoma-Headlight-Replacement-Headlamp/dp/B008UW8TC6
    You will also note that CAPA lights will come with high quality bulbs like Hella, whereas most aftermarket will come with a no-name brand.
