Need some opinions
Discussion in '1st Gen. Tacomas (1995-2004)' started by danescabare, Jun 3, 2008.
  1. Jun 3, 2008 at 8:41 AM
    danescabare
    danescabare [OP] Active Member
    Huntersville, NC
    00 Tacoma Prerunner Debadged
    Siruis radio, Debadged, elbow mod, deck plate mod...
    I am going to be driving from Charlotte,NC to Orlando Florida In my truck its a 2000 toyota tacoma its got about 85000 miles on it. This is going the longest trip I have ever takin it on does anyone have any tips or anything for me. I know about the oil and fluid levels and that is there aything else I should know?
  2. Jun 3, 2008 at 9:38 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Routine maintenance..... check all fluids including radiator & overflow tank. Don't forget air filter and tire pressure. Is your battery in good shape? How about running some fuel injector cleaner in it? Check your spare tire -make sure it's aired up. Make sure you have everything you need to change a tire if needed. Check your accessory belts for wear & tightness.
    Also - the main upper & lower radiator hoses - give them a good feel & squeeze. If you feel any thin spots - perhaps you should change them.
    And - you could also check the fluid levels in yoru transmission & atleast your rear differential.
    Hopefully - everything else is good (brakes, etc).
    Good Luck!
  3. Jun 3, 2008 at 10:09 AM
    danescabare
    Huntersville, NC
    I just filled up all the fluids, my battery is still good, im gonna run some fuel injector cleaner, I didnt even think about the tranny or the rear diff i might just change those thanks for the help
  4. Jun 3, 2008 at 11:40 AM
    AFBombdude
    AFBombdude Member
    Litchfield, AZ
    '01 PreRunner SR5
    Bone Stock for now
    Would be a good time to put some motor flush in it.
  5. Jun 3, 2008 at 12:04 PM
    rick
    rick `
    its a toyota, its barely broken in. as far as gas prices are concerned. they are a few cents higher near the exits of small towns. try to avoid them
  6. Jun 3, 2008 at 12:08 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Whats up Dane-you know that truck was built for the long haul man:) IMO Janster has nailed it as usual follow her advice. Hope you have a safe trip too:D
  7. Jun 3, 2008 at 12:26 PM
    danescabare
    Huntersville, NC
    I appreciate all the advice im just tryin to get everything ready
  8. Jun 3, 2008 at 12:28 PM
    danescabare
    Huntersville, NC
    That is another thing i didnt even consider doin
  9. Jun 3, 2008 at 1:32 PM
    danescabare
    Huntersville, NC
    Would you guys recommend using seafoam?
  10. Jun 4, 2008 at 4:03 PM
    AFBombdude
    AFBombdude Member
    Litchfield, AZ
    '01 PreRunner SR5
    Bone Stock for now
    That's good stuff!!
  11. Jun 4, 2008 at 4:09 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Are you going to have a load in the back or are you running lite ?
  12. Jun 5, 2008 at 5:21 AM
    danescabare
    Huntersville, NC
    pretty light just a couple of bags and a cooler
  13. Jun 5, 2008 at 9:31 PM
    747 function > form
    1st Gen.
    Make sure you take some tp...I went sockless halfway to Vegas a couple years ago because I forgot it. Oh, regarding your truck...it's a Toyota...no fear.
  14. Jun 6, 2008 at 6:06 AM
    danescabare
    Huntersville, NC
    I never thought about that tp on my list... I enjoy my socks
