Need Some Quick Help :) Toytec Adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Jul 7, 2010.
  1. Jul 7, 2010 at 11:16 AM
    SManZ
    SManZ [OP] el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I'm leveling out my truck and need some quick help. Do I move the adjustment collar on the toytec coil overs up or down to lower the ride height? I just turned the pass side a full turn and I don't think it lowered the height any. Its 100 deg out and I'm on tw on my phone :p
  2. Jul 7, 2010 at 11:21 AM
    06RedComa
    06RedComa Yotas For Life!
    Kyle
    Tempe
    06 4x4 DC Sport
    Camburg 2.5" Coilovers, Camburg 1.25" UCAs, Kings, Deaver Progressive leaf pack, AFE SI, TRD exhaust, Grillcraft grille, Bed Lights, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    Pretty sure you want the collar to come up if you want it lowered
  3. Jul 7, 2010 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Down. The adjuster is on the bottom of the shock, so it has to be moved down to lower.
  4. Jul 7, 2010 at 11:34 AM
    06RedComa
    Kyle
    Tempe
    06 4x4 DC Sport
    My bad, thanks for the correction Chris, my camburgs have them on the top and sorry for the confusion OP
  5. Jul 7, 2010 at 11:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No worries :)
  6. Jul 7, 2010 at 12:27 PM
    SManZ
    Haymarket, VA
    Thanks for the help guys! Lol I cranked them way up and the truck definitely had the lean to it. So back down it came.
    I know that fender to center of the hub is the normal measurement but I just wanted to even up so I measured from the top of rim to fender. The edge of the rim is a fixed point like the hub so I figured it was ok. I got 14.25" on the driver's side, 14.5" on the passenger side. Before I did it I had 15" on the passenger side. I can live with a half-inch difference.
    The whole point of leveling the ride was to keep the inner CV joint boot fins from touching each other, which was done!
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/98886-inner-cv-boot-fins-touching-wearing.html
