Need some reassurance!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YtridTaco1698, May 4, 2017.
  1. May 4, 2017 at 11:58 AM
    YtridTaco1698
    YtridTaco1698 [OP] Member
    Dj
    Santa Maria, CA
    2005 White Tacoma AC SR5 4x4
    billy 5100s tint, 33s on pro comps
    So i just picked up some bilstein 5100's and am planning to lift my truck up to 2.5" in the front with the stock coil (for now). The rear will have the stock oem set up but with 2" blocks which is currently on the truck right now. I also purchased 16x8 pro comp 7032's and 285 75 16 tires.
    Im fairly new to this stuff and am still learning along the way but just would like some reassurance with the set up i plan to have. Ive done my research and everything should be good to go, But will i run into issues i am not aware of??
    Some guidance is all im looking for, thanks! :D
  2. May 4, 2017 at 12:08 PM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    You might rub on the cab mount but I'm not sure
  3. May 4, 2017 at 12:08 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    I'll be the one to say it: you're not going to get reassurance on TW for a suspension plan that involves blocks and getting your front lift from the shocks instead of the coils. The ride will be stiff as hell on any setting that isn't 0 on the 5100s. And as I'm sure your research on TW has revealed, you may need to budget for UCA's at 2.5" up front to get back to specs on your alignment.
    I would advise that you consider other options that involve new coils and the proper length shocks in the rear. Good luck either way.
  4. May 4, 2017 at 12:18 PM
    YtridTaco1698
    Dj
    Santa Maria, CA
    Yeah I'm aware of that and don't have a problem with that.
    Id still need new UCA's just for 2.5"? Could I just eliminate all those issue by just sticking with a 265 tire?
  5. May 4, 2017 at 12:23 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    The need for UCA's is based on the 2.5" of lift that you're after, not the tire size. You may or may not need them but like I said you should budget for them.
    RigginsTaco likes this.
  6. May 4, 2017 at 12:23 PM
    scocar
    scocar hypotenoper
    The UCAs have nothing to do with your tire size. It is about your suspension geometry. The higher the lift, the harder it is to get enough caster into the alignment. Inadequate caster makes the truck more squirrely, and the steering wheel does not want to return to center. At 2.5 inches, this will start being an issue. Aftermarket UCAs provide additional range for adjusting more caster into the alignment.
    MadRiverTaco likes this.
  7. May 4, 2017 at 12:25 PM
    YtridTaco1698
    Dj
    Santa Maria, CA
    Oh okay I understand. Well I guess I'll just see what happens when everything comes together.
    Anything else I should know..?
  8. May 4, 2017 at 12:26 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    I'm running 5100s at bottom clip "0" with OME 885x coils and toytec 1/4" top plate spacer and am at 3" lift with 285/75r16 and SPC upper control arms. I rub cab mount at full lock in reverse and sometimes in drive when turning half lock and going up an incline
  9. May 4, 2017 at 12:28 PM
    scocar
    scocar hypotenoper
    Rubbing with 285s seems to be highly variable depending on specific wheel type and offset, tire brand/model (variation in same size across brands and models), and mudguards (those will need to go/be replaced with aftermarket).
  10. May 4, 2017 at 12:28 PM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    And @scocar is correct, you will want/need upper arms for alignment purposes regardless of tire size just due to the lift. If you stick with factory upper arms, your camber will be off and the factory ball joint will now be at an angle which will cause stress and pre mature wear or worse, failure.
  11. May 4, 2017 at 12:39 PM
    YtridTaco1698
    Dj
    Santa Maria, CA
    You guys know of any cheap UCA's I can purchase
  12. May 4, 2017 at 12:41 PM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
  13. May 4, 2017 at 12:42 PM
    YtridTaco1698
    Dj
    Santa Maria, CA
    txtaco87[QUOTED] likes this.
  14. May 4, 2017 at 12:42 PM
    YtridTaco1698
    Dj
    Santa Maria, CA
    So I can run the set up as is, but just the alignment is a possible problem that could occur?
  15. May 4, 2017 at 12:43 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    txtaco87 likes this.
  16. May 4, 2017 at 12:46 PM
    scocar
    scocar hypotenoper
    It will occur. A very competent alignment tech can reduce the effect to some degree, but not get it into "spec." feel. Most alignment techs suck at this and don't get it. At higher speeds on the freeway, you'll be working your steering wheel full time.
    MadRiverTaco and txtaco87 like this.
  17. May 4, 2017 at 12:46 PM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    At 2.5" lift with factory upper arms you'll end up wearing the tires out faster than normal due to alignment not being in spec. The SPC upper arms are adjustable and come with the spec sheet that they lay out on what to set it at. The balljoint is also removeable/replaceable with these arms. Your other option is a total chaos uniball style upper arm for $685
  18. May 4, 2017 at 1:02 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    They really do suck with aftermarket UCA's. Many don't even want to touch them. Especially tech's in the bigger shops that are trained for "toe & go" service.
  19. May 4, 2017 at 1:11 PM
    scocar
    scocar hypotenoper
    It seems the real struggle is the adjustable LR style, not the uniballs, which have no adjustment. Up top, anyway...
  20. May 4, 2017 at 1:46 PM
    MadRiverTaco
    Brenden
    Waterbury, VT
    Yes but even with uniballs they struggle to keep in mind that the truck is now lifted and aligning to factory caster specs as their computer shows just won't suffice. Maxing out caster while keeping camber and toe near 0 is a foreign concept to them. I'm actually going to seek out a 4X4 shop for my next alignment and see what they can do for me even though my numbers are quite good right now. Second opinions are always nice.
    scocar[QUOTED] likes this.
