Need some technical help
Discussion in '4 Cylinder' started by salserod, Dec 28, 2009.
  1. Dec 28, 2009 at 11:23 PM
    salserod
    salserod [OP] New Member
    Tucson
    98 Tacoma SR5
    My 98 Tacoma SR5 has some vibration in the engine only at idle and you can feel it in the steering wheel. Motor mounts and transmission mounts are good. Did the usual, air filter, new plugs and wires are good, clean air filter, cleaned the air flow meter. One of my friends said that the injectors may need to be cleaned so I put some Sea Foam recently and will try that out but I don't think that will work. Any suggestions are appreciated. It has 124k and runs great other than that vibration at idle.
  2. Dec 29, 2009 at 6:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What size 4 cyl.?
  3. Dec 29, 2009 at 9:29 PM
    salserod
    Tucson
    98 Tacoma SR5
    2.4 L 2 wheel drive.
