need some valve cover gasket help fellas
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04Prerunnertaco, Feb 23, 2014.
  1. Feb 23, 2014 at 7:47 PM
    04Prerunnertaco
    04Prerunnertaco [OP] Well-Known Member
    Canton, GA
    2017 silver sky trd 4x2
    Ok now I need some serious help. I needed to change the valve cover gasket because I was having a leak that was dripping on the exhaust. It started about 2 weeks ago its on the passenger side in the rear of the valve cover. Next to the tranny dip stick . When I would put my hand under the last bolt id pull it out and it would have oil. So I bought all the stuff and changed it today. I got all toyota parts. Valve cover gaskets, plugs, wires, new grommet s for the valve covers, new spark plug gaskets, and cam plugs. I also got FIPG to help seal. After I did it I let it sit for about 6 hours. Then went and litely washed the engine with degreaser . Drove it home and same problem dripping on the exhaust. Im pissed. I need some help. Ill see if I can post pics.
  2. Feb 23, 2014 at 8:01 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Are you sure its not your ac dripping onto it ?
  3. Feb 23, 2014 at 8:16 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Pics are the way to go.. Did you replace the Pcv valve?
  4. Feb 23, 2014 at 8:24 PM
    04Prerunnertaco
    Canton, GA
    Pcv replaced and grommet replaced. Ya im sure its not ac, you can tell its oil let me see about pics.
  5. Feb 23, 2014 at 8:33 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans/Baton Rouge
    97 TRD S/C 4x4 V6 5spd
    ICON/TC MidTravel TRD Supercharger
    Did you replace the cam plugs? Also, it may have have been the rear semi circle leaking. There is a semi circle plug at the front and rear of the heads. They are sealed with FIPG and can leak once the FIPG gets old. When I did my valve cover gaskets, I pulled these semi circles and re packed them with new FIPG.
  6. Feb 23, 2014 at 8:34 PM
    04Prerunnertaco
    Canton, GA
    Great write up. But I did all that.
  7. Feb 23, 2014 at 8:35 PM
    04Prerunnertaco
    Canton, GA
    I did do the full moon plugs , but no semis .
  8. Feb 23, 2014 at 8:55 PM
    04Prerunnertaco
    Canton, GA
    I cant figure out how to post pics.
  9. Feb 23, 2014 at 9:02 PM
    kigmob
    James
    Then my guess would be the rear semi circle plug leaking.
    As for posting images, I use this http://postimage.org
    Then copy and paste the link for forums in your post.
  10. Feb 23, 2014 at 9:06 PM
    04Prerunnertaco
    Canton, GA
  11. Feb 23, 2014 at 9:08 PM
    kigmob
    James
  12. Feb 24, 2014 at 10:57 AM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Your valve cover looks to be cracked as you stated, possibly someone over tightened it in the past to stop a leak. You might be able to clean it real well with brake clean let it dry well and seal it off with high temp silicone to get you by for now. Is that a 3.4 or 2.7?
  13. Feb 24, 2014 at 11:40 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Yup, someone else somewhere got excited tightening that bolt it seems. Could have happened at the assembly line with a defective torque set gun. Those cover bolts don't require as much pressure as one would think. If you put silicone down,,then crank that bolt down really tight,,you just wasted good silicone for the most part.
    Remove and JB weld after good prep,,inside and out. Don't put a timid little bead around there, You need to reinforce that corner by plastering it pretty good. Not much alum there for that hold down. Keep your sealing surfaces swiped clear of the epoxy.
    Or snag a junkyard cover if you can and want.
    It still might be those semi's leaking, adding to the mess,,if they weren't replaced and siliconed in.
  14. Feb 24, 2014 at 2:47 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
  15. Feb 25, 2014 at 3:59 AM
    04Prerunnertaco
    Canton, GA
    3.4
  16. Feb 25, 2014 at 4:01 AM
    04Prerunnertaco
    Canton, GA
    I did do the jb weld. I have been letting it cure as we speak. i also found a cover on ebay that I went and picked up just in case.
  17. Mar 14, 2014 at 7:10 AM
    Corn
    Corn Active Member
    00' Tacoma 4x4 ext. cab 3.4 ltr
    Fog lights added in 2002
    Hope you got your problem resolved. What torque pressure did you use when tightening the bolts? 53 in pounds?
  18. Mar 14, 2014 at 2:02 PM
    Connor12
    Connor12 Active Member
    Connor
    Texas / oklahoma
    1998 2.7 4x4 single cab
    toytec 3 inch lift springs and bilis shackles on rear
    i had the same problem the previous owner cracked the valve cover from over torquing it , so i had to dish out 80 dollars for a used good valve cover , so i replace it with a new gasket and some gasket seal and boom it was fixed
  19. Mar 15, 2014 at 9:48 PM
    KrzyKjun512
    KrzyKjun512 Well-Known Member
    Chad
    Pensacola, FL
    2000 PreRunner V6
    3 in coil spacers, NGK Ignition, AIRAID Filter, Mobil 1
    For those that don't know. 53 inch pounds is about 4.41 foot pounds...so just about hand tight :D
  20. Mar 16, 2014 at 4:49 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Yup, if you see inch-pounds, divide by 12 to get foot-pounds.
