need some wiring to battery help???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDfarmerTN, Oct 1, 2012.
  1. Oct 1, 2012 at 9:14 PM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    im wanting to do some bed lights, but wondered if theres any way to hook up the power wire without completly disconnecting the battery to where everything resets??? cause on my 2012 ive done had the seatbelt chime disabled and i dont wna have to do it again if all the electrical stuff is reset, the 12v battery saver thing wont work either from where we have to have our key turned on for cigarette lighter to work so that sucks....
  2. Oct 2, 2012 at 12:05 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't know if I was lucky or what. But on my 2012 I disabled the seat belt chime using the TechStream Software via the OBD2 connector. About two weeks ago I disconnected the battery to install and aftermarket head unit. The battery was disconnected for about an hour. When I connected it back up the seat belt chime was still turned off.
  3. Oct 2, 2012 at 12:35 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Don't worry about it. Once it's set, it's not going to change unless you want it done. Mine is disabled and I've unhooked my battery numerous times and it's still off.
  4. Oct 2, 2012 at 1:12 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    when connecting the wire to the battery, use a spade terminal (shaped like a 'U') then you only have to loosen the battery instead of completely unplug it to put a ring terminal on. If you tighten it down real good you wont ever have a problem with it.
  5. Oct 2, 2012 at 2:56 PM
    TRDfarmerTN
    i was thinking of this actually man!! glad u brought it up
  6. Oct 2, 2012 at 2:57 PM
    TRDfarmerTN
    maybe it will work like this and not reset!! did ur clock and radio presets reset??
  7. Oct 2, 2012 at 8:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Clock and radio, yes they will all reset.
