NEED STOCK STRUT ASSEMBLIES for 06 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cbookout89, Sep 4, 2011.
  1. Sep 4, 2011 at 9:09 AM
    Cbookout89
    Cbookout89 [OP] Well-Known Member
    Virginia
    2006 Toyota Tacoma TRD - SR5 4x4
    6" Fabtech Suspension Lift Satoshi Grille 1000W 2 -12" Sub System
    I have a 2006 Toyota Tacoma Sport SR5 w/ TRD package. It has the (yellow) 5100 Bilstein struts on the front but the lift shop is saying that the coil on the strut is over extended and I need the OEM coils. If anyone is interested in selling this to me Please let me know!!
    Thanks
  2. Sep 4, 2011 at 1:22 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    so do you only need the coil or both the coil and the strut assembly?
  3. Sep 5, 2011 at 9:31 AM
    Cbookout89
    Virginia
    Ok,
    I got a 6" fabtech lift kit on the truck. It had a 3/4" leveling spacer ontop of the front coils. After they took that spacer off the truck is still sitting about 1" higher in the front than in the back and the CV axles are wearing out. The lift shop is telling me that someone left the stock struts on the front of the truck and stuck an aftermarket coil ontop of it to level out the front of the truck.
    They are saying that I need the factory coils to bring the front of the truck back down so the CV axles do not continue to wear.
  4. Sep 5, 2011 at 9:32 AM
    Cbookout89
    Virginia
    And I can take a pic of my struts.
    They are Bilstein 5100's and they are yellow as yellow can be. With blue writing on them and they say Bilstein Toyota 5100
  5. Sep 5, 2011 at 9:33 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I'd like to see the pics. That lift should have come with a big spacer that went on top of the stock assembly.
  6. Sep 5, 2011 at 2:46 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Subbed for pics. I agree it sounds like they are not 5100s.
  7. Sep 5, 2011 at 8:53 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
  8. Sep 6, 2011 at 2:57 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Cookout, I sent you a PM. I have coils if you want them,
  9. Sep 6, 2011 at 3:44 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    SOMEONE PLASTI DIPPED 5100's :O
    :popcorn:
  10. Sep 6, 2011 at 11:42 AM
    Cbookout89
    Virginia
    Ok, to clarify and i will post pics tonight.
    I went to the dealership and took a pic under a 2010 same truck as mine and it has the yellow 5100. I see what everyone is saying.
    But besides that issue. The lift shop did put a block ontop of the strut assembly, but my truck sits 1" higher in the front end. Does anyone have any other suggestions as to what I can put on the front end to bring it down to level out the truck and to get the angle out of my poor cv axles?
    Can those billy 5100's that are zinc go under the front end? I am new to lifting but have learned ALOT.
    Thanks.
  11. Sep 6, 2011 at 11:45 AM
    KPT
    09 Prerunner
    To clarify again, the yellow bilstein shocks are NOT called 5100's. They are called HD's.
    The thing on top of your shock (not strut) is called a top-plate spacer (not a block). If the truck sits higher in the front end, remove the top plate spacer and boom, there you go.
  12. Sep 6, 2011 at 11:47 AM
    Cbookout89
    Virginia
    One more thing sorry to double post.
    But the lift shop ALSO said that (and i know ive said it before) that not only did my truck have a leveling plate on the front end, it has a over extended coil ontop of the factory strut to bring the truck up even more. Also it has a AAL kit on the back so basically it had a 2" lift. I wanted it all off and just the basic 6" fabtech. Well the back of the truck did fine, the front....well took the plate off and truck came down some, but now they say coil needs to be changed back to factory or just need a new strut assembly. whichever is easiest
    BUT if anyone has any suggestions about something I can put under the front end to use i am open for suggestions. I have looked into dirtlogic coilovers but with hunting season in 1 month $$$ is going somewhere else. :)
  13. Sep 6, 2011 at 11:48 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you have factory struts on their now and the coil is too tall, switching to the silver 5100's won't help. It sounds like you've got a lift coil on there right now and want to go back to stock height? If that's so, 2 people above offered you stock coils... I've got a set of stock coils and struts (assembled) off a 2007 but I'd have to ship them if you want them.
  14. Sep 6, 2011 at 11:50 AM
    Cbookout89
    Virginia
    Ok i believe you. Thats why i came here for help. Can i put Billy 5100 under the front of my truck?
  15. Sep 6, 2011 at 11:52 AM
    Cbookout89
    Virginia
    PICTURE.
    HERE is the picture BEFORE they took off the 3/4 leveling spacer. now that the spacer is gone the angle of the CV axles are half as bad.
  16. Sep 6, 2011 at 11:53 AM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Albuquerque & Palo Alto
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    :confused: I want to see these pics!
  17. Sep 6, 2011 at 11:53 AM
    KPT
    09 Prerunner
  18. Sep 6, 2011 at 11:57 AM
    Cbookout89
    Virginia
    Ok they are the HD struts. Sorry. How can I be sure that the coils are lift coils?
  19. Sep 6, 2011 at 11:57 AM
    Cbookout89
    Virginia
    Ok sorry my phone keeps cutting off my post. Everyone please PM me with maybe a pic? and the prices with shipping to 23838;:eek:
  20. Sep 6, 2011 at 12:07 PM
    Pugga
    Massachusetts
    F-150 Mod
    Can you post a pic of the top of the coil? From the bottom, that looks like a stock TRD suspension. You might not need any new parts if we can figure out what was done to your truck.
