Corresponding part numbers for 3rd gen leaf springs to 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Not a golfer, Jun 19, 2022.
  1. Jun 19, 2022 at 4:40 PM
    Not a golfer
    Not a golfer [OP] Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    My leaf springs are done and I want to replace them. I know there's lots of options but can get a set of 3rd gen leaf springs for $300.
    My Truck
    2012 Double Cab TRD Sport Auto totally stock
    I have a consistent load of about 500 lbs between my Leer topper and tools.
    Leaf springs I'm looking at came off
    2021 Double Cab TRD Off Road Auto
    Part numbers
    48220-04241
    48210-04601
    Will these fit my truck?
  2. Jun 19, 2022 at 4:55 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    Yes, they will fit. Your part numbers are correct. I just replaced a set of leafs from a 2nd Gen with a set from a 3rd Gen TRD OR and they had the exact part numbers you listed.
  3. Jun 19, 2022 at 4:56 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Yes they will fit. I put springs from my 2021 onto my 2006.
    Ricardo13x likes this.
  4. Jun 19, 2022 at 5:46 PM
    Sean42
    Sean42 Well-Known Member
    You should be able to get them much cheaper than $300 I got mine for free.
  5. Jun 19, 2022 at 6:31 PM
    Not a golfer
    Calgary, Alberta
    Excellent
    Thank you everyone. I looked at other posts just couldn't find those part numbers.
    I don't have a problem with $300 it's better than the bad leaf springs I have now.
  6. Jun 19, 2022 at 6:41 PM
    All Visible Hues 14
    All Visible Hues 14 Well-Known Member
    Lynn
    East Tennessee
    2014 dcsb TRD off road
    Is there any lift to be gained from this swap other than restoring the truck to the original ride height?
  7. Jun 19, 2022 at 6:43 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Those practically new springs along with some sumo springs and/or maybe an AAL should float your boat. With the weight you're carring you need one or the other with OEM leaf springs. Or, you might look into a set of Deaver leaf springs that are "sprung" to fit your needs.
  8. Jun 19, 2022 at 6:45 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Anyone know if there is a difference between these and the 2nd gen recall leafs springs?
  9. Jun 19, 2022 at 7:19 PM
    BlkDakDave
    David
    CC TX
    2+ overland on pre-recall to 3+ overload on recall pack.
  10. Jun 19, 2022 at 7:27 PM
    Alealexi
    Houston, TX
    Ok... Let me clarify... Is there a difference between the 3rd gen leaf springs being referenced and the 2nd gen recall springs.
  11. Jun 20, 2022 at 6:45 AM
    BlkDakDave
    David
    CC TX
    Gotcha, you want to know the difference between 3rd gen leaf springs and the 2nd gen recall leaf springs. I'm pretty sure they are the same, but I've haven't compared them next to each other. I did a google search and found this thread.
    https://www.tacomaworld.com/threads/tsb-leaf-springs-and-3rd-gen-or-same.644626/
    If you go with stock 3rd gen or 2nd gen recall leaf springs you're going to need something to assist with the load you carry. I have a Leer cap and keep containers full of camping and riding gear in the bed all the time. I also use either a hitch carrier or pull a utility trailer when I head off to the boonies. When the recall springs, with that extra leaf were installed, I was hoping it would help with the constant load I carry around. I soon realized it did not so I added sumo springs first then added an AAL. Both were easy to intall, but in retrospect a set of Deaver leaf springs may have been the best route.
  12. Jun 20, 2022 at 6:59 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    They will fit. I would go to say they are the same thing? Maybe someone correct me if Im Wrong.
    but I would advise that you also get a beefier leaf pack. 500lbs constant load will wear out the 3rd gen leaf pack pretty quickly as well. And if you are paying $300? Might as well spend a little more and get something beefier. I got 2 different ome leaf packs, like new off Craigslist for 400 each.
    BlkDakDave likes this.
  13. Jun 20, 2022 at 7:00 AM
    DG92071
    DG92071 Well-Known Member
    3/4" lift on my 2nd gen using 3rd gen leaf springs. I definitely wasn't happy with 3rd gen leafs with ~400 lbs of tools hauled around 24/7.
    2ndhandTacoman and BlkDakDave like this.
  14. Jun 20, 2022 at 11:12 AM
    Huckin Grate
    Huckin Grate Well-Known Member
    Calgary, Alberta
    2008 SR5 MT V6 4x4
  15. Jun 23, 2022 at 7:48 PM
    Not a golfer
    Calgary, Alberta
    Can't thank everyone enough for all the feed back.
    I've decided to purchase springs from Standen's here in Calgary. They will build a custom spring pack to fit my needs (supply and installed for about $1000).
    Huckin Grate, MSgt O and BlkDakDave like this.
  16. Jun 25, 2022 at 10:26 PM
    Huckin Grate
    Calgary, Alberta
    2008 SR5 MT V6 4x4
    Nice. Update us when you get it - I've debated that route myself. Keep given'r man
  17. Jul 6, 2022 at 2:10 AM
    Frez1812
    Frez1812 Well-Known Member
    2012 Tacoma 4.0
    I have a 2012 ext cab 4x4 base model. Found a set of leaf springs from a 2022 TRD, was wondering if they will bolt right up on my truck?
    Alealexi likes this.
  18. Jul 6, 2022 at 4:28 AM
    BlkDakDave
    David
    CC TX
    Yes and you will get an inch or a little more on the front with the struts.
  19. Jul 6, 2022 at 4:29 AM
    Frez1812
    2012 Tacoma 4.0
    Already did the shock and struts.
    BlkDakDave[QUOTED] likes this.
  20. Jul 6, 2022 at 4:47 AM
    Alealexi
    Houston, TX
    Yes and you will get a 3/4 inch lift in the rear.
