Need suggestions on a good (inexpensive) jack
Discussion in 'Garage / Workshop' started by 28ØØ3, Nov 18, 2012.
  1. Nov 18, 2012 at 6:40 AM
    28ØØ3
    28ØØ3 [OP] Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    So the jack that came with the truck is basically worthless. Are there any good, inexpensive jacks that I can use to jack up one side of the truck to do my tire rotation? Are any of the harbor freight ones worth a damn?
  2. Nov 18, 2012 at 6:46 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    You can usually find a deal at Sears for a good alum one pump to touch jack and maybe the stands included. I forget how much it was but that is the set up I got my father in law
  3. Nov 18, 2012 at 6:54 AM
    barker14
    barker14 sexual ninja
    Adam
    Nova Scotia, Canada
    05 Tacoma TRD Off Road
    Complete OME suspension with Dakar leaf pack. Clarion touch screen Sport hood Tri fold Tonneau cover
    Just go for a cheap set with a jack and stands if your truck is stock height. If your lifted you will need bigger stands and a taller jack or use some wood to extend the height. Not sure why I even have the stock jack in the truck still. All the way up it doesn't even reach the frame...
  4. Nov 18, 2012 at 7:26 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Are you looking for a bottle jack to replace the factory one in case you are on the side of the road? Floor jacks out of the question?
  5. Nov 18, 2012 at 9:35 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    floor jack
  6. Nov 18, 2012 at 9:41 AM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
  7. Nov 18, 2012 at 9:56 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Torin big red from advance auto. Cheap, but seems to work well.
  8. Nov 18, 2012 at 10:02 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    x2, I forget which package, but for under $100 you can two jackstans and a floor jack rated for 3 tons, plus the creeper. I have had no problems with mine.
  9. Nov 18, 2012 at 10:08 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    So far I've had decent luck with my Harbor Freight.
    The "dirty little secret" of the floor jack industry is they rate the capacity of the jack as the ENTIRE WEIGHT OF THE CAR assuming it's evenly distributed between front and rear axles. If you read enough fine print on these labels, you'll find this out.
    So a "2 ton" jack does NOT lift a 4000lb axle on an 8000lb truck. It lifts a 2000lb axle on a 4000lb car.
  10. Nov 18, 2012 at 6:11 PM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    thanks for your input guys. so i need/want a 3-ton jack, correct?
    i will keep an eye out for some good black friday deals
  11. Nov 18, 2012 at 7:28 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, and if you're lifted, make sure that the height range is sufficient to raise the truck high enough for you to work on it.
  12. Nov 18, 2012 at 7:34 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    If you did want to go cheaper, technically you could go with a 2.5 or even 2 ton jack. Your truck is right under 2 tons (right under) stock; if you went with a lower rated jack but got stands for 2.5 or greater you would be okay. It makes it more difficult to lift but it can be done, and typically it would bd cheaper. If you do go under 3 ton, also consider any additional equipment added to your truck.
  13. Nov 18, 2012 at 7:43 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
  14. Nov 18, 2012 at 7:43 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Remember, on a pickup, the front's a lot heavier than the rear.
    So don't go less than 2.5. I have a 2.5 I got (because it had more height range than the 3T) and I wouldn't want any less when lifting the front - and I have a four banger reg cab.
  15. Nov 18, 2012 at 7:46 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    I edited my post in his other thread. Looking at the specs, the 4x4 dc is actually right over 2 ton; I told him to go at least 2.5, but 3 for ease of use.
  16. Nov 24, 2012 at 5:04 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
  17. Nov 24, 2012 at 6:37 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
  18. Nov 24, 2012 at 6:45 AM
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    i wasn't going to fight the herds of morons yesterday, some of those are black friday 3-day deals
    i did go to Best Buy at around 2pm and picked up a Toshiba Canvio external hard drive for $40.....they were hidden and i think that's why no one found them
  19. Nov 24, 2012 at 6:52 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Nice, how many GBs or TBs?
  20. Nov 24, 2012 at 7:33 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.7" URD Pulley, APR X1, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Alcan aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, m/t atz 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
