Need suggestions on lift. And pics if you have them..
Discussion in 'Suspension' started by mainewoodsballer, Nov 15, 2011.
  1. Nov 15, 2011 at 8:05 PM
    mainewoodsballer
    mainewoodsballer [OP] YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    I have a 2011 TRD Sport and I would like to lift it and put some bigger tires on the stock rims. What type of lift are people using and what size can fit on my rims without rubbing?
    I was looking at lifts such as the rough country that just has the 2 in block in the back w/ shocks and 3 in spacer in the front. I dont really want anything to fancy. Any suggestions help. Im just not sure what to get..
    Post your pics if you have any! Thanks!
    This is how it sits now stock
  2. Nov 15, 2011 at 10:52 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    ^^^ Sounds great, spacers all 4 corners and you're good!
    PS - The dealership can put one on for you too!
  3. Nov 15, 2011 at 11:37 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    :facepalm:
    Come on dude, I know you're tired of newb questions but you don't need to be giving them shitty advice. Just don't post if you don't want to help.
    OP,
    Do some searching around on here for some more info, but spacers/blocks are not recommended.
    Just because you don't want fancy doesn't mean you can't do it right. 5100s up front, along with the TSB rear leafs will be a nice setup that will ride well and while it will not let you fit 285s, you can still have a little lift to go along with new tires.
    As it is right now, you can fit 265/70-17s. If you are wanting to go bigger than that, you will be looking at new coils, new UCAs to allow for proper alignment, etc...
    Fink
  4. Nov 15, 2011 at 11:56 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I know I iust couldn't resist! :deadhorse:
  5. Nov 16, 2011 at 4:59 AM
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    Same truck same boat. Got 5100s and aal on the way from toytec. Nice truck. Is it possible to put pics from my iPhone on here?
  6. Nov 16, 2011 at 7:56 AM
    Fink
    Orlando, FL
    You can with Tapatalk, or you can host them with Photobucket and then use the tags.
    Fink[IMG]http://cfink.smugmug.com/photos/i-LgFpTrs/3/M/i-LgFpTrs-M.gif
  7. Nov 16, 2011 at 2:03 PM
    mainewoodsballer
    Ol' Waltah
    Maine
    Actually I was thinking of just going to walmart and getting some hockey pucks...:)
  8. Nov 16, 2011 at 2:07 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    check out my build thread. i love the way my truck sits and i think it is the perfect height but that is just my opinion. billies and aal are a great "inexpensive" lift and it is a pretty simple install if you have the right tools and a buddy who doesn't mind helpin ya out
  9. Nov 16, 2011 at 4:37 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    heres all 4 bilsteins at 1.75 in the front and the TSB in the rear. 265/70/17s
    love it too
  10. Nov 16, 2011 at 5:29 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    My apologies to OP, 5100's all around with the front set at desired height is the way to go! Spend some time reading about diff lift options in this suspension section and get an idea of what works and what guys are running. I got a little frustrated because it's been covered a few times before, no hard feelings!
    Good luck!
