Need Supercharger question help quick???
Discussion in '1st Gen. Tacomas (1995-2004)' started by MTNative, Jul 26, 2011.
  1. Jul 26, 2011 at 7:28 PM
    MTNative
    MTNative [OP] Well-Known Member
    I found a (Trd generation 1 supercharger for 3.4L) and need to know if this will fit an '04 3.4L? If so what is it worth? Thanks
  2. Jul 26, 2011 at 7:37 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I believe it does, the 3.4L is only in the 1st gen Tacos which run from 1995 - 2004
  3. Jul 26, 2011 at 7:38 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Yes it will fit your truck.
  4. Jul 26, 2011 at 7:41 PM
    MTNative
    Okay cool, is $450 worth taking a chance? It is suppose to have everything including hoses and belts.
  5. Jul 26, 2011 at 7:42 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    It should be worth it even if it has to be rebuilt. I got mine for $2,700 with the charger and 7th injector kit.
  6. Jul 26, 2011 at 7:47 PM
    MTNative
    7th Injector kit? What is that and is it required? Thanks for the help on this one. Want to buy it for my '04 but hesitant not knowing much about them.
  7. Jul 26, 2011 at 7:51 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    It is a piggy back system that makes it run better and most will say it is required and I would recomend it to get the most out of the supercharger. The kit can be found at URD a vendor on here.
  8. Jul 26, 2011 at 7:59 PM
    MTNative
    Sounds like I just bought a supercharger. :D I will look into the 7th injector. Thanks for the help and I may be looking you up for some more info later.
  9. Jul 26, 2011 at 8:02 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Cool man if I can I'll help. Is it the grey one or black one?
  10. Jul 26, 2011 at 8:06 PM
    MTNative
    It was grey but he painted it black with red TRD.
  11. Jul 26, 2011 at 8:08 PM
    MTNative
    When I go pick it up should there be anything I need to look close at, bearings, shafts, etc?
  12. Jul 26, 2011 at 8:12 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Cool same one I have. Well you would have to take it apart to look at all that and I wouldn't know what to look for. I know if you have any doubts with it call the guys over at High speed lab they can rebuild it for you for around 400-500$ so worst case scenario you are in about $1,000 for a supercharger.
  13. Jul 26, 2011 at 8:20 PM
    MTNative
    Will do and what will this 7th injector run me? Might have to get that overnighted put on this weekend if it isn't to much.
  14. Jul 26, 2011 at 8:32 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    It is also aroung $1,000 but IMO worth it.
  15. Nov 2, 2011 at 11:12 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Make sure your CAI (Cold air intake) is compatable with the S/C for starters. some aren't but most are. but you'd rather be certain.
    3000$ +tax and install seems a lil high to me, not too bad, but I'm sure you could negotiate that price a little bit
    Exhaust is not Required, but it would be useful in order to get the most power out of your upgrade
  16. Nov 2, 2011 at 11:14 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    marcel your advice is null since we dont have pics of yours installed
    make that build thread!!!! :D
  17. Nov 2, 2011 at 11:18 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Heres a pic of it sitting on my living room floor..... best I got... :anonymous:
  18. Nov 2, 2011 at 11:19 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    lies
    All i see is a beer bong tube and an old vacuum
  19. Nov 2, 2011 at 11:22 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    You should see the size of my beer bong, 3 stories tall, 3-stage 1.5 horsepower water pumps. Takes 2 kegs to fill it.
    The running score is: Bongasaurus 3 kills - Humans 0
  20. Nov 2, 2011 at 11:25 PM
    Ripcord
    Ripcord KM6PIM
    Jim
    Colorado
    Spruce Mica 13' DCSB OR
    When you go to look at the S/C, Just be sure the blow off valve is intact and everything. They can be damaged easily on shipping and stuff. Also check for any play in the nose drive. And check to make sure all the bolt holes are intact, they are known for breaking off.
    Here a few a sites on basic supercharger knowledge..
    http://www.gadgetonline.com/Super.htm
    http://www.customtacos.com/forum/showthread.php?t=154201
    http://www.ultimateyota.com/index.php?option=com_openwiki&Itemid=60&id=wiki:trd_3.4l_supercharger
    You will want to change the oil in it when you get it.
    Extra things you will need are the TRD "O" throttle body gasket, OEM check valve, new belt for S/C (might as well replace all the drive belts while you're down there too).. Thats all I can think of.
