Need Suspension help
Discussion in 'Suspension' started by ecjr173, Nov 26, 2012.
  1. Nov 26, 2012 at 4:52 PM
    ecjr173
    ecjr173 [OP] Well-Known Member
    Eli
    Buena Park, Ca.
    07 TRD Sport PreRunner SR5
    Hey guys not sure if I can describe my issue but here it goes. I have icon coil overs set at about 2.5". The rear of the truck is stock height. I know it's got some bro lean going but that will be fixed with wheelers progressive aal. So my issue is that my truck gets thrown all over the road when I go over some rough patches of road (Potholes, bumps in the road). My steering wheel rattles and shakes during this. My truck rides great if the road is smooth but once i hit the rough patch, it's all over the road. What can be causing this. Is this normal.
    Thanks
  2. Nov 26, 2012 at 5:00 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    Wyoming
    2012 TRD Off Road Double Cab V6 6Speed
    Checked steering links? Over rough roads my steering column clunks by my feet which is normal for 2nd gens.
    That's all I got...
    ~M
  3. Nov 27, 2012 at 7:50 PM
    ecjr173
    Eli
    Buena Park, Ca.
    Would there be anything else that can cause my truck being thrown all over the road on a rough patch. I'm not feeling or hearing any clunking by my feet from the steering column.
  4. Nov 27, 2012 at 11:08 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    10 TRD off road doublecab 4x4 silver
    plenty
    Caster and tie rod angle will induce bump steer. Sounds like you need a set of aftermarket UCA's and a good alignment.
