Need Switch Panel Wiring help!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rdGenTRD, Apr 2, 2023.
  1. Apr 2, 2023 at 4:08 PM
    3rdGenTRD
    3rdGenTRD [OP] Certified
    Jeremy
    Gulfport, Mississippi
    2016 TRD OR Super White
    Body Amor bumper with high clearance wings 5100s with 2888s JBA Uppers Ray10s 17x8.5 -10 285/70/17 Toyo Open Country M|T Icon 3 Pack AAL rear 5100s Full AJT interior red with oversized cup holder Auxbeam 8 switch panel Diode 6” and round fogs
    Excuse my ignorance when it comes to DC please, I’m trying!
    I recently installed the auxbeam 8 gang switch panel and 6” diode dynamic amber fogs in my BA bumper. I’m using the supplied wiring harness pig tails they sent with the lights.
    Question 1) wiring size? I’m going to assume 14ga would be okay?
    Question 2) wiring multiple lights to one switch on the panel. Do you wire them both all the way to the spot on the panel where it plugs in or should I just run one light to the other light then from there go to the switch panel?
    I have decent knowledge of AC power but never really messed with DC until recent so bear with me. 9F581E96-BCD3-4AA0-A12D-47EF887CC5DC.jpg
  2. Apr 2, 2023 at 4:11 PM
    LkdTaco
    LkdTaco Well-Known Member
    2019 TRD PRO
    If I wired anything on mine……
    soundman98 likes this.
  3. Apr 2, 2023 at 4:25 PM
    3rdGenTRD
    Jeremy
    That’s how I feel lol
    LkdTaco[QUOTED] and kahanabob like this.
  4. Apr 2, 2023 at 4:37 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    According to Diode Dynamic SS6 draw 26.6w per light
    For those 16ga wire would be plenty.
    I used 16ga wire for my 18w chase lights (which are spliced together) and for my 180w lightbar.
    For my larger 9" lights I used 14ga wire. They draw 250w together and I probably should use 12ga for them but I only plan on using them for short amounts of time so it should be fine for now.
    3rdGenTRD[OP] likes this.
  5. Apr 2, 2023 at 4:42 PM
    3rdGenTRD
    Jeremy
    Perfect thanks, so as far as wiring them to the panel. Should I wire one light to the other and then from there to the panel or run two wires to the panel and put them together inside where they screw to the panel?
  6. Apr 2, 2023 at 4:47 PM
    ssd2k2
    Keith
    Minnesota
    On my chase lights I wired them together then ran one wire to the panel.
    Good 14ga wire should be able to handle 15a.
    So 26.6w x 2 = 53.2w / 12v = 4.4a
  7. Apr 2, 2023 at 5:01 PM
    3rdGenTRD
    Jeremy
    Thanks for the help man. I thought I could do it this way. I accidentally ordered 18g and I knew I needed 16 or bigger
  8. Apr 2, 2023 at 5:16 PM
    caribe makaira
    Caribbean, Puerto Rico
    If it's only the pair of lamps I'd do the later. Only 2 wires at the module. Also, if you get a connector to isolate the lights, in case one fails. One can be removed from vehicle while the other continues its job.
    Similar to this:
  9. Apr 3, 2023 at 3:45 AM
    3rdGenTRD
    Jeremy
    Thanks! I was looking for one like this actually. Found some on Amazon.
