Need Tacoma Mechanic!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Krock, Aug 29, 2009.
  1. Aug 29, 2009 at 7:43 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    Just curious if anyone knows a mechanic in the Philadelphia area that can help me diagnose a problem with my 2000 Taco V6 4x4 manual tranny?? There is a roughness while driving that has developed and I can't tell if it is coming from the drivetrain or the engine.. It's driving me crazy!
    I need a local non-dealer Taco expert around Philadelphia to help.
    Any ideas??
    Thanks
  2. Aug 29, 2009 at 7:48 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    We can help you diagnose it. Is it a vibration at certain speeds?
  3. Aug 29, 2009 at 7:51 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    No Vibration. A low humming noise, almost grinding. I can feel it in the gas pedal. It's much loader when the engine is above 2800 rpm's. I feel like the truck doesn't have near the power my older V6 had. My guess was the tranny or transfer case or diff's. Who knows, maybe the engine~!
    Thanks for the quick response.
  4. Aug 29, 2009 at 7:54 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    P.S. Engine Oil Changed along with both Diffs and still noise. Can't seem to figure out how to check or change tranny fluid??
  5. Aug 29, 2009 at 7:54 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    What do you have? 4 or 6 banger?
    Miles on the truck?
    EDIT: HAHA missed the 6 banger in the original post.
  6. Aug 29, 2009 at 7:55 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    they had problems with the oil in the trannys and diffs for a while it was to thick and cause u vibration try changin the oil maybe
  7. Aug 29, 2009 at 7:56 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    148,000 on the V6. Just bought it for a really good deal. Manual Tranny
  8. Aug 29, 2009 at 7:56 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    No Vibration, Just a very rough sound
  9. Aug 29, 2009 at 7:58 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    On the driverside of the tranny is the fill (towards the top). On the bottom should be the empty. They are large flat bolts (23mm I think). Take them both out. I find it easier to fill the tranny through the shifter (less hassle)
  10. Aug 29, 2009 at 7:59 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You need to use a GL-4 fluid, NOT THE GL-5.
  11. Aug 29, 2009 at 8:00 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Has the timing belt ever been changed?
  12. Aug 29, 2009 at 8:00 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    That is my next task for sure!
  13. Aug 29, 2009 at 8:02 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    Very Good Question on the Timing Belt? Not Sure.. Would the engine begin to feel rough as the belt stretches looses timing??
  14. Aug 29, 2009 at 8:03 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It is very possible, and the loss of power. The change interval is 90k on the 3.4l.
  15. Aug 29, 2009 at 8:03 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    What is the frequency for timing belt on my Taco??
  16. Aug 29, 2009 at 8:05 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    That sounds like a good thing to take care of regardless! What do you think a ballpark cost would be??
  17. Aug 29, 2009 at 8:05 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    90k miles. If it hasn't been changed it is way over due.
  18. Aug 29, 2009 at 8:07 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No clue. Most people do it themselves. It is a weekend type of job and not really that hard if you are mechanically inclined. It isn't difficult, just involved.
  19. Aug 29, 2009 at 8:07 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  20. Aug 29, 2009 at 8:07 PM
    Krock
    Krock [OP] Member
    Kristopher
    Philadelphia
    00 Tacoma
    Yeah! I am going to get the clutch, timing, and water pump all at once..
