Need TacomaWorld's HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hudhawk, Dec 1, 2011.
  1. Dec 1, 2011 at 6:55 PM
    hudhawk
    hudhawk [OP] #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Ok, so last night i was hangin out at a friends house. He lives on about 4 acres. He told me that he had made a cool little trail that went through the brush behind his house and asked if i wanted to see it. Being the curious person i am, i said yes. Anyway, about halfway through the trail i hit a huge whole, and i came down pretty hard on my passenger side front tire. Now it was dark and this was a trail i had never driven before, and I will be the first to admit that i was driving it a bit too fast and it not a good idea. When i left i noticed that the truck was pulling to the left so i figured that i had just knocked it out of alignment. I took it to get aligned after class today and they couldnt get the passengers side camber into spec. The tech told me he maxed out the adjustment and the closest he could get it to was -1.4 degrees of camber, which i verified by looking at the monitor for myself. Anyway, when i got back i did a complete visual inspection of the suspension. the only thing that i noticed that made sense was the lower control arm being slightly bent on the end where it narrows down and copnnects to the balljoint. Im going to post the pics i have so you all can tell me what you think. I know the truck is rusty, i live on the coast, everything rusts no matter what.
    THANK YOU!!!
    The night it happened, before alignment:
    After alignment:
    Passenger side (Bad side):
    This is where i think it is bent:
    Driver side (Good side):
  2. Dec 1, 2011 at 6:59 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I did not mean to double post this. Im very sorry. im not sure how it happened. Mod can delete one of the two.
  3. Dec 1, 2011 at 7:53 PM
    Joe D
    Joe D .
    Hudson,
    I sure can't tell by looking at it if it's bent or not. You had zero problems before the impact?
  4. Dec 1, 2011 at 7:59 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Pics are so rusty it is really hard to tell. I wouln'd keep driving it like that.
  5. Dec 1, 2011 at 8:22 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    From the pic it doesn't look bent but it could be. Take some measurements and find out... only real way to tell. And yea... that is rusty... once you get it fixed up I'd be under there at least once a year with some rustoleum just to help protect it... just say'n.
    Not sure how hard you hit but I beat the hell out of mine and they'll take some good abuse. My LCA is still stock, UCA is total chaos. Check your UCA out too.
  6. Dec 1, 2011 at 8:30 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Dam. Hud, friends don't let friends drive through skecthy trails haha
  7. Dec 1, 2011 at 8:40 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Yeah, sketchy is right. I'll be taking apart the front end this weekend to take some measurements and figure it out.
