Need TacomaWorld's HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hudhawk, Dec 1, 2011.
  1. Dec 1, 2011 at 6:56 PM
    hudhawk
    hudhawk [OP] #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Ok, so last night i was hangin out at a friends house. He lives on about 4 acres. He told me that he had made a cool little trail that went through the brush behind his house and asked if i wanted to see it. Being the curious person i am, i said yes. Anyway, about halfway through the trail i hit a huge whole, and i came down pretty hard on my passenger side front tire. Now it was dark and this was a trail i had never driven before, and I will be the first to admit that i was driving it a bit too fast. When i left i noticed that the truck was pulling to the left so i figured that i had just knocked it out of alignment. I took it to get aligned after class today and they couldnt get the passengers side camber into spec. The tech told me he maxed out the adjustment and the closest he could get it to was -1.4 degrees of camber, which i verified by looking at the monitor for myself. Anyway, when i got back i did a complete visual inspection of the suspension. the only thing that i noticed that made sense was the lower control arm being slightly bent on the end where it narrows down and copnnects to the balljoint. Im going to post the pics i have so you all can tell me what you think. I know the truck is rusty, i live on the coast, everything rusts no matter what.
    THANK YOU!!!
    The night it happened, before alignment:
    After alignment:
    Passenger side (Bad side):
    This is where i think it is bent:
    Driver side (Good side):
  2. Dec 1, 2011 at 6:59 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I did not mean to double post this. Im very sorry. im not sure how it happened. Mod can delete one of the two.
  3. Dec 1, 2011 at 7:08 PM
    TacoTitan11
    TacoTitan11 Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
  4. Dec 1, 2011 at 7:15 PM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Each picture you took is at a different angle so it's tough for me to see a slight bend.
  5. Dec 1, 2011 at 8:06 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Did you compare the upright (spindle)? These have been known to bend, moving the tire into a position similar to what is shown.
    Check the clearance between the tires inner sidewall on each side.
    PK
  6. Dec 1, 2011 at 8:46 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I'm going to go ahead and say its not the spindle. I have Camburg spindles, I think I'll probably snap the lower control arm in half before I bend my spindles.
  7. Dec 3, 2011 at 11:16 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Didn't realize you had aftermarket spindles from the photos and honestly did not pull up your build list.
    With that info, possibly you did bend the lower arm.
    PK
