Need tire expert advice, please help!!
Discussion in 'Wheels & Tires' started by AFTaco, Oct 10, 2010.
  1. Oct 10, 2010 at 4:11 PM
    AFTaco
    AFTaco [OP] Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    Hey guys,
    IK, I tried searching but came up with too much that really didnt apply to my situation. I need everyones expert advice on tire size.
    I have a 2009 DC TRD OF with a short bed. It has factory lift/suspension. I did have the TSB AAL done on the rear. My question is, can I fit some BFG's KM2 285/75/16 on the truck with a factory lift and wheels? I know that it will probably rub, IDC about that, I can trim. I just wanna know if I can install these on factory rims and suspension without doing major body work. Can this be done with only minor trimming? I do plan on getting the Toytec Ultimate in the near future. Thanks for all your help!
    Doug
  2. Oct 10, 2010 at 4:17 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    No. I have a similar truck: 2010 Sport, and I wanted to run 285/70/17. Everyone advised me that I needed a lift. I have the lift now, and am saving for the tires. By the way, good choice on the Toytec. That's what I have installed now.
    I used the tire calculator on http://www.tacomaworld.com/forum/tirecalc.php
    Results: the tires are virtually identical in size (yours vs. mine). If I need a lift, you should too.
    ps: I was also advised that I should use spacers as well, which I have now. (Spidertrax)
  3. Oct 10, 2010 at 4:19 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Nope, 285's won't fit on stock suspension. I had to remove the front mud flaps to clear 265 Duratracs.
  4. Oct 10, 2010 at 4:23 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    You would need a lot more than minor trimming.
  5. Oct 10, 2010 at 4:27 PM
    AFTaco
    Doug
    Anchorage, Alaska
    TRD Off-road
    Thanks guys! I can get a great deal on them for $900 here so I was wondering. If I buy the tires now, install the lift, then it would be minor trimming with factory 16's? Thanks again
  6. Oct 10, 2010 at 5:35 PM
    SCFirefighter
    Stephan
    Cary, NC
    Are you sure $900 is such a great deal? Near $1K sounds like regular retail price.
  7. Oct 10, 2010 at 8:48 PM
    AFTaco
    Doug
    Anchorage, Alaska
    TRD Off-road
    Yes. Up here in Alaska, the normal price is 11-1200 for 4. So yeah, 900 is a steal for 4 285/75/16. Im not sure if I want to get them though, or just get 265/70/16. I don't want to buy new tires and it will be about 3-4months before I can get my lift. What do yall recommend I do?
  8. Oct 11, 2010 at 6:07 AM
    Archangel
    Archangel Insurance Agent
    Charlotte, NC
    '11 Jeep Grand Cherokee Laredo E
    RRO leveling kit, Billy 5100's, Gibson axle-back exhaust, K&N CAI, Yakima Roof Rack, JK Rubicon wheels, 8K LED low, mid, and highs,
    go with the 265/75/16's for now and put your lift on. when the time comes to replace, then replace with the 285's
  9. Oct 11, 2010 at 6:26 AM
    SCFirefighter
    Stephan
    Cary, NC
    Get your lift and stick with your current tires until you can buy the tires you want. Again, you might have to spend an additional $200 for the Spidertrax spacers. Get your truck ready first, and then worry about getting the matching tires.
  10. Oct 13, 2010 at 9:26 AM
    AKtoyTaco
    AKtoyTaco Well-Known Member
    Adam
    Anchorage, AK
    2011 TRD Double Cab
    I'm up here in Anchorage too, and tires are definitely more expensive. Where did you find them at that price in town? I'm looking at a new tire set up as well. Thinking about getting 285/70/17 studded Duratrac's for the winter and the same size KM2's in the spring.
    I've got King coilovers and a 1.5" Deaver leaf pack in the back and am planning on doing a good bit of trimming myself with the bigger tires.
    Would love to find a cheap place to buy tires in town though.
  11. Oct 13, 2010 at 12:44 PM
    mainland_newfie
    mainland_newfie Mainland Newfie
    ontario, canada
    TRD Tacoma
    skid plate, side step rails, new rims, hose clamp, 20% tint, G4 Tonneau cover, JVC 7 in double din stereo/dvd
    on my stock suspension (4 leafs though), I am currently running 285/50r/20's without any rubbing.
  12. Oct 17, 2010 at 2:43 AM
    AFTaco
    Doug
    Anchorage, Alaska
    TRD Off-road
    Sorry for the long delay, that price is on base with a coupon. Coscto sells the KM2's for around 248 though. Usually BFG has rebates every so often.
