Need Tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by slickyd, Oct 8, 2009.
  1. Oct 8, 2009 at 10:52 AM
    slickyd
    slickyd [OP] Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    I need 2 new front tires. I don't really go off ride a lot and they would mostly be for highway use. I wouldn't mind some A/T's. The ones on the back are some "Fusions" They seem like ok tires but are there any better ones. I don't want them to be too loud while driving. Any help would be great. The size i need is 265/70R16.
  2. Oct 8, 2009 at 11:00 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    if your truck is 4wd all 4 tires need to be the same :D
  3. Oct 8, 2009 at 11:01 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    its 2wd but i didn't know that.
  4. Oct 8, 2009 at 11:11 AM
    David Tarantino
    N.J.
    08 tacoma
    ck the the firestone destination le or
    the general HTS :D
  5. Oct 8, 2009 at 12:23 PM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    I wouldn't say they need to be the same. It's a good idea if they were. Just like it's a good idea to change all 4 but not necessary. I would not recommend 2 mismatched tires on the front and 2 mismatched on the back.
  6. Oct 8, 2009 at 12:31 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    PIRELLI SCORPION... have had them for about 20k and very happy with them... great traction in snow and rain... never really been in the mud tho... kind of expensive tho... about as much as michelin...
  7. Oct 8, 2009 at 12:35 PM
    David Tarantino
    N.J.
    08 tacoma
    on a 4wd all 4 tires do need to be the same you may do damage
    to the trans and or deff i have seen it many times :D
  8. Oct 8, 2009 at 12:37 PM
    Ktaco
    not any different then having 2 more worn then the others. I can understand 2 different sizes but not thread pattern.
    But i'll agree to disagree :)
  9. Oct 8, 2009 at 12:43 PM
    David Tarantino
    N.J.
    08 tacoma
    ok then we will :D
  10. Oct 8, 2009 at 1:01 PM
    David Tarantino
    N.J.
    08 tacoma
    There are several suggestions that have been offered to drivers who are replacing pairs or individual tires on their four-wheel drive and all-wheel drive vehicles. Some vehicle manufacturers recommend that all tires maintain the same rolling radius and circumference, while others suggest that all tire circumferences remain within 1/4- to 1/2-inch of each other. Other vehicle manufacturers recommend that all four tires remain within 2/32-, 3/32- or 4/32-inch of each other, or within 30% of each other in relative remaining tread depth.
    Regardless of the vehicle manufacturer's recommendations, the least stressful application is when all four tires are the same tire brand, tread design and equivalent tread depth.
    Before buying pairs or individual tires for all-wheel drive and four-wheel drive vehicles, drivers should read their vehicle's owners manual or contact the dealer's service department for confirmation of their specific vehicle's requirements.
  11. Oct 8, 2009 at 3:40 PM
    Tacoguy
    Tacoguy Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    Nitto Terra Grapplers FTW!
  12. Oct 8, 2009 at 3:49 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    get nitto A/Ts dont go the cheap way and only change 2..... change all 4
  13. Oct 9, 2009 at 6:55 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    dont just change 2. you gotta do all four. I mean, you dont HAVE to, but you really really should.
  14. Oct 9, 2009 at 7:08 AM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    x2 Nitto Terra Grapplers
