Need to box rear frame with steel bumper
Discussion in 'Technical Chat' started by achirdo, Jan 5, 2011.
  1. Jan 5, 2011 at 9:23 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    http://www.ttora.com/forum/showthread.php?t=167612
    Read there that they say u need to box the rear frame to keep it from tweaking/bending after adding a heavy steel bumper in the back. Is that really neccessary? Is that not a little over the top? I've never even read anything like that here. Thoughts anyone?
    Discuss
  2. Jan 5, 2011 at 9:46 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Interesting thread link.
    I would think that as long as bumper weight < rated bed capacity you'd be fine. Although, it's acting out on the end of the frame, so I guess the force would be multiplied. I wouldn't think it'd be enough to tweak the frame though.
    That's armchair engineering though, and that statement has absolutely no basis in fact.
    I bet Chris4x4 has something to add to this one :)
  3. Jan 5, 2011 at 10:35 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i wpuld like a good answer to this as well
  4. Jan 5, 2011 at 10:41 PM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    shouldnt have to box/plate it just from adding a rear bumper. but alot depends on how you use it too. if you just drive around town then no, it wont be needed. but if your always winching or towing off of it, then it probably wouldnt be such a bad idea.
  5. Jan 6, 2011 at 2:37 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Id like to know others opinons as well. We know the Tacoma is not a truck made for towing/hauling HEAVY loads. But with a around 85 pound rear bumper and a small camper or boat hooked up to it with gear in the bed, would it be to much for our trucks to handle? If so my uncle is a welder and Ill take my truck to him and have him box it in for me. :confused::D
  6. Jan 6, 2011 at 1:37 PM
    achirdo
    Adam
    North DFW
    bump. anyone else? got some good feed back?
  7. Jan 6, 2011 at 1:43 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    Free welding, might as well go for it !:taco:
  8. Jan 6, 2011 at 1:59 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    The offroad bumpers aren't significantly heavier than the stock with the trailer hitch. You'd be surprised how much that thing weighs.
  9. Jan 17, 2011 at 9:38 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Yea Id say together there around 60-70 for stock. Iv taken mine on and off before both the bumper and hitch. But I gotta plan for mine that SHOULD strengthen the rear frame without boxin it in. I will try any design it and see if it will work, and if it will, I will post a write up! :D
