Need to confirm...Sorry for rehashing
Discussion in 'Suspension' started by samer312, Jun 12, 2013.
  1. Jun 12, 2013 at 4:17 AM
    samer312
    samer312 [OP] Well-Known Member
    Sam
    Alexandria VA
    2020 Cement TRD OR
    Want to replace some of my suspension because it rides like crap and it looks likes its lowered:eek:
    with some ome shocks and coils (without spacers) how much lift can get? I want to know because need to figure out how much of an aal lift I will need. Also with this setup will I need to extend the brake lines?
    Thanks any sorry for asking the obvious-so much information on lifts, sorta hard to find what you need
  2. Jun 12, 2013 at 4:42 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    this site will tell you how much lift you can expect per coil you choose
    EDIT: looks like this is for 95-04; i would imagine it's gotta be right around the same, though
  3. Jun 12, 2013 at 6:51 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    OME claims you get 2" from their full kit but it's really more like 2.5" from what everyone is reporting on here.
    This is the wheeler's site for the 2nd gen tacoma:
  4. Jun 12, 2013 at 7:03 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    You have a prerunner, why not get lift spindles? Coil lifts are no good in terms of ride quality. Unless your coils need to be replaced really bad, I wouldn't do coils.
  5. Jun 12, 2013 at 7:35 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I disagree with you 100% on that. I think the lift coils and better shocks ride 1,000x better than stock. The stock suspension is soft up front and bouncy in the rear. Stiffer coils paired with properly valved shocks keep the ride much more controlled, reduce body roll in corners and also reduce brake induced nose dive.
    If you want over 3" of lift with a Prerunner, I would agree that spindles are a great option. If you think the stock ride is poor, spindles won't change that.
  6. Jun 12, 2013 at 9:05 AM
    samer312
    Sam
    Alexandria VA
    2020 Cement TRD OR
    That's why I asked, would i like a lift?-sure, but I have 120,000 on the odometer and the truck is starting to have major body role/look about a half in shorter in the front compared to stock (to much driving in dc...).
    So would just coils and shocks give me three inches-just want to know for rear lifting purposes, and would I HAVE to get new brake lines?
  7. Jun 12, 2013 at 9:12 AM
    Pugga
    Massachusetts
    Check out the OME lift kit with Light Racing upper control arms. That will get you to 3" of lift. For the rear, either an AAL or replacement leaf pack. A leaf pack would be better but not everyone wants to drop that kind of money on a lift. The OME kit for the front does not require new brake lines, depending on what you do for the rear, brake lines might be required, just depends on how tall you go. Most people won't put the same lift front and back. The rear usually gets a little less lift so the truck rides level.
    If you could find some new front coil/shock take-offs, a spindle lift is a great way to lift a Prerunner. If you liked the suspension when it was new and stock, that would be a good way to go. If not, start looking aftermarket!
  8. Jun 12, 2013 at 9:40 AM
    samer312
    Sam
    Alexandria VA
    2020 Cement TRD OR
    thanks for the help
