Need to find the correct wheel size for 2wd tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by ein9, Oct 8, 2010.
  1. Oct 8, 2010 at 9:43 PM
    ein9
    ein9 [OP] Member
    Need to find the correct wheel size for 1998 2wd tacoma regular cab. automatic
    the dealer says it takes a 6x14" or a 5x14" rim (wheel) if i remember correctly my 1999 tacoma was a 5" rim not sure i remember having 195 75r/14 tires on it if that helps any. the dealer doesnt seem to know which one is best they say it comes with both tires so which is the right tire i gave them my vin number they still could not specify which is the right one they said i could put both of them on.
    is there a spec sheet or an online site that would give me enough detail to find which exact size of rim is best. Does anyone have a 2wd what size is your rim
    Also which rim is better is the wider one going to be to wide or will it give a better ride.
    Thank you for your efforts and have a nice day.:):):):D
  2. Oct 8, 2010 at 9:46 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have an 04... I'm pretty sure it has 15" wheels though. I know my tires (same size as factory) are 205 75 R15
