need to know: does the OME lift change alignment specs?
Discussion in 'Toytec Lifts' started by MurphyZ, Oct 9, 2010.
  1. Oct 9, 2010 at 3:10 PM
    MurphyZ
    MurphyZ [OP] Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    i was at firestone on Barksdale AFB, after 4 and a half hours for an alignment (life-time, only way to buy) they said that my caster was .4* out of alignment.
    I told them that with my OME lift, top spacers and Light Racing UCA's my alignment will spec on the alignment machine.
    the shop lead said' "Because of your 3in lift, factory spec will not work-even if we spec it, we can not guaranty the alignment. Adding or removing height will cause the factory lift specs to be incorrect."
    i tried to tell them that with the UCA's and the lift that you can indeed spec the alignment to factory standards and that is more than fine.
    he asked for toytec to send him a letter telling him if there were "different" specs for the lift.
    If you would, please send a fax to firestone of Barksdale's store manager, Joel Jackson a letter showing him he is wrong.
    thanks 20k on the lift and no issues
    Murphy
  2. Oct 9, 2010 at 3:32 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    phone
    318 747 6888
    fax
    318 747 7771
  3. Oct 11, 2010 at 7:24 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    anyone from toytec....
    i need an answer to get an alignment again.
  4. Oct 11, 2010 at 7:37 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes it does. You want.....
    Camber: 0°
    Toe: 0°
    Caster: 2.4°- 3.1°
  5. Oct 11, 2010 at 7:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    I don't think those are "different" Those are the stock specs IIRC. Without the UCAs you might have trouble getting to those specs- but with them- There should be nothing preventing you from getting the right specs.
    Do you have the specs they DID get for you??
  6. Oct 11, 2010 at 7:50 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  7. Oct 21, 2010 at 10:14 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    yes everything is in spec but the turds couldnt get my caster in spec, .4* out right now...
    firestone of barksdale AFB is saying that with a lift they will not garrenty the lifetime alignment...
    ome 3" with LR UCA's this is bull and this isnt the first time appearantly. some others on base say they are screwing with trucks with lifts.
  8. Oct 21, 2010 at 10:32 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Light Racing UCA's? Who installed them?
  9. Oct 21, 2010 at 11:41 AM
    Brunes
    Brunes abides.
    Rotorhead
    And were the adjustments made or were they just thrown on?? Those Firestone guys get paid by the job...So they make 40 bucks for every alignment....if your alignment takes 4 hours- They are going to get to a point where they aren't going to try very hard any more.
  10. Oct 21, 2010 at 9:51 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    The LR UCA's have a additional 2 degrees of caster built in and they are also adjustable 2 degrees in either direction. Your alignment guy should be able to set it pretty much where ever he wants. The specs we recommend are
    Camber: 0 degrees
    Toe in: 0.04 degrees
    Caster is the 2.4-3.1 degrees
    Which way is the caster out of spec?
  11. Oct 22, 2010 at 6:10 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    i put them on and i put the flat edge towards the rear adn did the ol roll the truck back with the top nut loose... then had an alignment 6 months ago.
    got new tires and now firestone is being a turd.
    toytec lifts- i love the set up and i have told them that the control arms work, they just did shabby work..
    found my alignment sheet
    camber
    .9* 0.0 .9*
    caster
    2.1* (-.9*) 2.8*
    toe
    -.01* .02*
    for the front of course
  12. Oct 22, 2010 at 6:13 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    as to your specs toytec lifts it looks fine right?
    had another shop do this alignment, told them if they did it i would buy there lifetime alignment...
    and get a refund from firestone
