need to know
Discussion in '1st Gen. Tacomas (1995-2004)' started by tvtoy60, Oct 3, 2014.
  1. Oct 3, 2014 at 7:15 AM
    tvtoy60
    tvtoy60 [OP] New Member
    tim
    knoxville tn.
    95 tacoma
    tire guys, will 32-11.50-15s fit under first gen. with no lift and a 3.0 inch offset rim. this is 95 stock truck.
  2. Oct 3, 2014 at 10:48 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is a whole lot of offset. Did you mean 3" of backspacing? How wide is the wheel?
    On stock wheels (15x7 with ~4.6" bs), you might be able to get away with minimal clearancing of the pinch weld area. On a wider wheel with less bs you will definitely rub a lot on the pinch weld.
