Need to pick brains about programming.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twalt87, Apr 18, 2017.
  1. Apr 18, 2017 at 12:23 PM
    Twalt87
    Twalt87 [OP] Well-Known Member
    Travis
    Vancouver island Bc
    I have a 2012 with the Sai bullshit. Not under warranty and I refuse to replace them.
    It dawned on me today that this may or may not work.
    2011 trucks did not have sai. Could I essentially grab a 2011 ecu and program the vin to my truck? Or essentially programming all the cms to think it's 2011.
    I have a programmer at my shop, so I can fully reflash ecms. As long as the connections are the same this could possibly work no?
    Thoughts? Should I get a used one and just give it a go?
  2. Apr 18, 2017 at 12:33 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    ECM connectors are different.
  3. Apr 18, 2017 at 12:37 PM
    Twalt87
    Travis
    Vancouver island Bc
    Yea i saw that after looking around.... shoulda looked before posting lol.
    If only i could disable the sai using my programmer lol
  4. Apr 18, 2017 at 4:16 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
  5. Apr 18, 2017 at 4:27 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    secondary air intake
  6. Apr 18, 2017 at 4:40 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    It's not recommended to use one year's ecu flash on a different year. ECU flashes are linked to vin number... different range VIN numbers have different offset calibrations (likely because if engine production variations), and could cause very poor engine performance or damage...or could even brick the ecu if you put an incorrect flash, and require a jtag type reprogram for revival which requires expensive developer type tools.
    Unfortunately it's not as simple as doing as doing a iOS or windows update.
  7. Apr 18, 2017 at 4:42 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Whenever I hear the expression "pick brains" I think of the ancient Egyptians picking the brain out through the nose with a wire hook before mummifying the deceased.
    Taco47 likes this.
  8. Apr 18, 2017 at 4:48 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Your best bet is to learn HEX code, dump/decrypt/decompile/edit/encrypt/recompile Toyotas ECU code, Become a fucking legend, profit. I doubt this will happen with the level of expertise it sounds like you have with the programmer at your shop and how it works.
    You're next closest bet is something that will simulate the effects of the Secondary Air Intake.
  9. Apr 18, 2017 at 4:49 PM
    mbrogz3000
    Northern NJ
  10. Apr 18, 2017 at 5:01 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    I believe there is a elimination / bypass kit available for your truck. It's about $350.
    RacecarGuy likes this.
  11. Apr 18, 2017 at 6:16 PM
    Twalt87
    Travis
    Vancouver island Bc
    Which works out to being 470cad plus shipping/duties/other border bullshit its more on the 600 line of things.
    I knew it wasn't going to be simple, I wasn't planning on reflashing my ecm to an older year. My original question was already answered with the wrong plugs. As for decrpyting the ecu, nah, im good there haha.
    Ill build my own bypass for now.
