Need to replace all brake fluid...How do I?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by divad94, May 19, 2012.
  1. May 19, 2012 at 5:48 AM
    divad94
    divad94 [OP] Active Member
    David
    Ivor, VA
    05 Tacoma PreRunner SR5 2WD
    K&N air filter
    Would like to flush and refill brake lines but im not sure where to start(rr,lr,etc)and the correct procedure for doing this. Any advise appreciated.
  2. May 19, 2012 at 6:22 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
  3. May 19, 2012 at 6:29 AM
    CrutchfieldDarren
    CrutchfieldDarren Well-Known Member Vendor
    Darren
    When bleeding brakes you always start with the wheel that's farthest away from the Master Cylinder. So RR, LR, RF, LF.
    Use something to get out all the old fluid you can from the reservoir. Fill it up with new clean fluid, I always use DOT 4 because of its higher boiling point. And don't use a can of fluid that's been opened, it draws moisture.
    Get some clear tube that will fit the bleeder tip, and a small cup of fluid. Put the hose on the bleeder tip, stick it down in the fluid. This does a couple things, keeps air from getting sucked back in, let's you see the air bubbles coming out much easier.
    Don't forget to keep the reservoir full, very important. You can keep the lid off during the process. You will need to bleed each wheel till you see fresh clear fluid coming out with no bubbles. Oh, did I mention to keep the reservoir full! :)
    Hope this helps!!
  4. May 19, 2012 at 6:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's much easier to have a 'buddy' help you with the bleeding process. My husband always works the bleeders while I work the pedal....
  5. May 19, 2012 at 6:46 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Another trick is to use a diff color fluid. Like Super Blue. When the color changes, you've flushed it. Next time around, you go back to amber, etc.
    bax likes this.
  6. May 19, 2012 at 7:10 AM
    CrutchfieldDarren
    Darren
    Like that tip Elmo!
  7. May 19, 2012 at 9:21 AM
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    super blue is very good fluid and does make a flush easier (the next time you need a flush by the gold-same fluid just "normal" color)
    what I really like for flushing a brake system is one of these- A Motive self bleeder http://www.motiveproducts.com/ , you pour new fluid into the unit, attach to the MC, pump it up and then go from bleeder to bleeder- couldn't be easier and it does a better job of bleeding than pumping the brakes
    not sure if they have a specific adapter for the 2nd gen Tacoma, but will find out soon :)
  8. May 19, 2012 at 9:32 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Posted this from FSM few years ago but here is the process to bleed brakes (replace fluid)
  9. May 19, 2012 at 1:14 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    id use the vacuum pump method. no worries about bottoming your master cylinder
  10. May 19, 2012 at 1:38 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    And be VERY careful what you touch with the brake fluid on your hands!!!!
    Don't go and caress any painted or plastic part of your vehicle with even a little residue on your hands.
  11. May 19, 2012 at 1:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And do not ever ever allow the master to go dry.
    If you allow air to get pulled beyond the master and into the ABS unit, you will need to take it to a shop that has the proper equipment to bleed the ABS unit. You can't just "push" the air through the ABS unit the way you do the calipers.
    Doable as a one-man job, but definitely better to have at least a 2nd pair of eyes.
  12. May 19, 2012 at 2:06 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    This post just made my day. My wife will be upset though, there's another $100 tool I need to buy.
  13. May 19, 2012 at 2:17 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  14. May 19, 2012 at 2:38 PM
    big sky
    Montana
    ^ I have to give that guy an A for innovation :)
  15. May 21, 2012 at 7:42 AM
    divad94
    David
    Ivor, VA
    K&N air filter
    Great reply's all, I do appreciate it. Ill be changing the fluid soon. Thanks again.
  16. May 21, 2012 at 8:09 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    some will argue that ATE super blue is more of a racing fluid and will absorb more water. logic is that racers change fluid much more frequently.
    i use to use it in my track car..(now i use Motul, which absorbs even more water)., but i hated how it dyed everything blue. my reservoir is blue, my motiv speed bleeder is blue, my hose is blue..hate it.
    now i just know..couple of bottles, call it good.
  17. Aug 14, 2012 at 3:23 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I ordered a Motiv Bleeder with the universal cap (0100). The 2gen reservoir doesn't easily allow the conical shaped cap to fit. I could get it to hold maybe 5psi but no more and even then, it leaked down.
    I called the support number, described my problem and was sent a steel bar to that some 4Runner guys use. This didn't help as much as I'd hoped.
    So, I called back and agreed to meet Eric at the shop (I live about 45 min or so from their shop).
    When I arrived, I was able to demonstrate the problem easily. It's really difficult to get the cap to seat because the reservoir doesn't allow for the chain to pull straight down on the cap-which is why it leaks.
    What I ended up using was this. It fits in the reservoir and seals correctly to about 10psi. One caution though. You absolutely want to use a strap of some sort to insure it doesn't pop out. And you want to use some cleaner to clean the mating surfaces.
    I'll post some pictures later. But so far, this has worked well.
  18. Aug 14, 2012 at 7:31 PM
    big sky
    Montana
    thanks for the update- too bad they couldn't come up w/ something a little easier
  19. Aug 14, 2012 at 8:13 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    A big part of the problem is how the Toyota reservoir is designed. As you're aware, the cap doesn't lock on. If it did, then it'd be easy. Gotta say that locking the pressure fitting on is definitely a hell of a lot easier than the universal cap ;)
  20. Aug 15, 2012 at 6:16 AM
    divad94
    David
    Ivor, VA
    K&N air filter
    With all your advise the brake fluid change went very well. I did old fashion way and had a helper to pump the brake pedal. We found discoloration and what looks like condensation in the fluid. Truck had 110,000 mi on it. Took little effort to change fluid as all your inputs helped us out. Thanks again to all.
