Need to replace all brake fluid...How do I?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by divad94, May 19, 2012.
  1. Aug 15, 2012 at 6:25 AM
    BamaToy1997
    Bill
    Navarre, FL
    Make sure you look up proper procedure. certain manufacturers and ABS systems actually do not follow the "furthest first" method of bleeding.
  2. Aug 15, 2012 at 6:42 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I suck the fluid out of the master res, then refill with clean fluid and bleed until its clean out of the bleeders. Bam, done.
  3. Sep 27, 2012 at 3:42 PM
    Markus9u
    Markus9u Markus9u
    Markus
    Texas
    2005 Texas Edition
    Borla Exaust system, Doug Thorley headers, Injen powerflow cold air intake, URD performance chip, Train horn w/ 150 psi, Bushwackers, RBP Grill, Westin Bull Bar, Piaa lights, HID Projectors 8K, Pioneer Avic-X 930bt, Remote start?Alarm.
    How many quarts would a full flush be?
  4. Sep 27, 2012 at 3:56 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
  5. Sep 27, 2012 at 5:50 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I just bled my brakes today. However, if you have a 2gen, you might not want to get the universal adapter. I could never get it to seat properly and if it comes off while you are bleeding the brakes, you will get brake fluid all over the place. Even if you have no fluid in the jug (the test part), if that pops off, you're screwed. I know this from experience :eek:
    I called Motive and ended up going to their shop to show them what was happening. I ended up leaving this this. It worked great-you still want to secure it so that it does not pop out (I used a piece of safety wire). But otherwise, it works perfectly. I was able to get the brakes bled in about 20 minutes.
    In addition to the Motive bleeder, you will need about 36oz of fluid (that's three of the smaller bottles or one large bottle of fluid). I used a high temp DOT3 fluid. You probably won't use all of it but you want the jug to contain enough fluid in it to cover the pickup.
    The procedure is simple:
    • Attach the bleeder to the reservoir. Do not put any fluid in the system.
    • Pressurize the jug to about 10psi. Wait 5 or 10 minutes and verify you haven't lost pressure in the jug.
    • Slowly loosen the top of the jug. When it's depressurized, fill it with your brake fluid and pressurize it to 10psi.
    • Following the procedure, bleed the brakes starting with the farthest wheel from reservoir-when the fluid comes out the color of the new fluid (and with no air bubbles), move on to the next wheel. Repeat until done.
    • While you are working, periodically check the jug to make sure it's not run out and that it has enough pressure to complete the job. Also, and this is important, be sure your brake reservoir does not run out of fluid. If it does, you will need to head to the dealer to bleed it-on the back of a tow truck. If the ABS runs out of fluid, you need the Toyota Intelligent Tester to finish bleeding the system.
    • Check the level in the reservoir and top off if you need to. Then test the brakes.
    • When you're done, drain the remaining fluid from the jug and piping and clean the jug and piping with alcohol.
    Good luck!
  6. Sep 28, 2012 at 10:14 AM
    BTO
    California
    It says it's for radiators. Is that correct?
  7. Sep 28, 2012 at 11:36 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    That's what it says and it is what I used. Call 'em up if you have questions.
    They're really helpful.
  8. Sep 28, 2012 at 12:59 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Anything that will fit the cap and apply GENTLE pressure will get the job done.
    Just don't apply so much pressure that you blow the reservoir off of the master, and don't let the reservoir run dry.
    If you get air into the lines, the only place it has to go is out through the ABS unit, and you need Techstream and the proper connectors to bleed the ABS unit.
    Don't use air from a compressor. You are introducing air into a reservoir that is full of fluid. The airspace is very small. Pressure increases extremely quickly.
    I used to have a pressure pot for testing underwater lights and camera housings. Just a tube with a 1" plexi top bolted down and a Schraeder valve.
    Filled with water, just 1/4" or so of air at the top....
    Just a couple of pumps with a bicycle pump would get me to point of simulating a 400ft dive.
  9. Sep 28, 2012 at 1:24 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Hey Rich. The device we are discussing is designed for bleeding brakes and has a small pump built into it to charge the jug.
  10. Nov 21, 2013 at 5:15 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Thread revive!
    Will this baby (http://motiveproducts.3dcartstores.com/0101-Round-Universal-Bleeder-_p_132.html) work on a 1st Gen no problems? or do you have to order some special adapters for them too?
  11. Nov 21, 2013 at 8:25 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
  12. Jul 19, 2014 at 12:45 PM
    mattygaff
    mattygaff Beat em
    What size tubing did you guys use to fit snugly on the brake bleeder valve on the 2nd Gen? Thanks.
  13. Jul 20, 2014 at 12:05 PM
    divad94
    divad94 [OP] Active Member
    David
    Ivor, VA
    05 Tacoma PreRunner SR5 2WD
    K&N air filter
    I used a 1/4 inch but it my vary on yours. Check your brake bleeders for correct size for your vehicle because im sure they vary between make and model.
  14. Jul 20, 2014 at 4:15 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    1/4".
