need to replace catalytic converters on 2002 tacoma ext cab 4x4.
Discussion in '1st Gen. Tacomas (1995-2004)' started by fevertreefan, Jun 5, 2011.
  1. Jun 5, 2011 at 7:16 AM
    fevertreefan
    fevertreefan [OP] Member
    new jersery
    02 4X 4 extended cab
    the dealer wants $2479 (ouch) and ideas on how i can get it done cheaper?
  2. Jun 5, 2011 at 7:19 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Go to RockAuto.com, order new cats and install them yourself. That or go to any exhaust shop in your area.
  3. Jun 5, 2011 at 7:32 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    BWWAAAHHHHAHHAHAHA...
    but seriously. My quote for that fix was ~$1420 from a Toy dealer. You could have a muffler shop fab up everything for waaay less with much better components.
    magnaflow universal hi-fow cat and generic tubing + new muffler and possible new 1/1 o2 sensor and instead of 1/2 buy the URD sim o2 and you'd be out the door for under $500 depending on muffler chosen and shop install costs and you'll have a much better performing system.
    search for "p0420" and you'll have enough reading to figure out what to do.
    *$500 purely a 'ballpark' spec your own stuff out, talk to a local shop. And if you wanted to get the official Magnaflow replacement front, you'll add ~$200. If you're a 2 cat system, and you choose to (or need to for insp.) have 2 cats, add a few hundred more. Do some searching, there are many, many ways to do this cheap and right.
    *EDIT* Also, are you getting any specific codes?
  4. Jun 13, 2011 at 1:01 AM
    trded
    trded Active Member
    CA
    02 PreRunner TRD 2WD
    TRD Catback TRD Headers TRD SuperCharger TRD 7th Injector & ECU
    you can try to "revive" your cat. i did it to mine and was able to squeeze out an extra 6 months out of my cat. just removed it and unloaded a can of carb cleaner into the honeycomb. after that i literally hosed the cat with water. worked for 6 months and passed smog.
  5. Jun 14, 2011 at 6:01 AM
    fevertreefan
    new jersery
    went to menike muffler shop and got system replaced. after they replaced it the #2 sensor was not working (maybe bad it first place?). So replaced that all together $800. I drove for 2 days and engine light came on again. So took it back. They had to order direct mount for front cat. I take it the one that they put on was wrong. So waiting to hear from them when they get part it. I was assured that there will be no cost to me. Wait and see.
    3
  6. Jun 14, 2011 at 6:58 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Is it possible that you dumped Sea Foam into the intake via the brake booster, looking for some magic and that killed your cats?
  7. Jun 14, 2011 at 7:21 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Did they tell you what the code was for the check engine light?
  8. Jun 16, 2011 at 4:03 PM
    fevertreefan
    new jersery
    that's the code
  9. Jun 16, 2011 at 4:20 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Had to be a 420. There isn't 240. 99% of the time the 420 is a bad rear 02. You may have paid $800 for a bad sensor.
  10. Jun 16, 2011 at 4:30 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    sea foam won't do that will it ??????
  11. Jun 16, 2011 at 4:34 PM
    JDMcQ
    Hasn't hurt my truck. Of course I've only done it once.
  12. Jun 16, 2011 at 4:37 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Highly doubt it. There are thousands of people who use it without negative effects.
  13. Jun 16, 2011 at 4:58 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    URD O2 Simulator:D
  14. Jun 17, 2011 at 7:20 AM
    fevertreefan
    new jersery
    yeah i asked about that and the mechanic said that was the reason the cats failed. what pissed me off is the dealer said the cats were bad but didn't say anything about the sensor. it seems like everybody is out to rape you so they are looking for the most expensive options instead of the least expensive options.
