Need to reprogram TPMS each time I change wheels?
Discussion in 'Wheels & Tires' started by Sgt.Tee, Jan 12, 2019.
  1. Jan 17, 2019 at 4:31 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
  2. Jan 17, 2019 at 4:32 PM
    Pushincaskets
    High Point, NC
    07 PreRunner DCSB
    You place all ALl 4 programmed sensors inside a pvc tube that is sealed on both ends and has a valve stem. You pressurize the tube to xxpsi. Voila all sensors see the right pressure. Drive around with the tube in truck and Eau is happy.
  3. Jan 17, 2019 at 5:40 PM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    I don't think this works with 3rd gen trucks. The newer trucks need to read which corner of the truck each sensor is located. One benefit is we get a digital read out of each tire pressure. I do also check them manually.
    Eta: I stand corrected. Sounds like it would work.
  4. Jan 17, 2019 at 5:45 PM
    trdt44
    Trent
    Utah
    2017 Tacoma TRD OR
    From my research i have found that aftermarket sensors don't work well with the 3rd gen Tacoma's. The best options i have found are OEM or Denso, who makes the OEM sensors.
  5. Jan 17, 2019 at 5:49 PM
    Pushincaskets
    High Point, NC
    07 PreRunner DCSB
    Still works it is only reading what sensor is assigned to that corner not that it is actually in the corner.
  6. Jan 17, 2019 at 5:59 PM
    trdt44
    Trent
    Utah
    2017 Tacoma TRD OR
    I never could find confirmation that it would work. May have to give it try. Seems like I read that when the tires are rotated it will eventually learn the new sensor location without pushing the reset button. I figured the computer would eventually get confused because it could not figure where the sensor is located.
  7. Jan 18, 2019 at 4:18 AM
    Sgt.Tee
    Sgt.Tee [OP] Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    With all these problems, I am leaning on no TPS on the new set. I hear mixed reviews, this will work this will not work. Time to get a piece of black tape and just cover the light when it comes on. Thanks for all the advice and tips
  8. Jan 18, 2019 at 5:30 AM
    Sgt.Tee
    Pete
    NE Pa
    Game plan, no tpms on new wheels, I will block out that yellow light everyone is talking about with a piece of tape if it bothers me
