Need to switch coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mirraman, May 17, 2012.
  1. May 17, 2012 at 11:24 AM
    mirraman
    mirraman [OP] Well-Known Member
    Tim
    Ventura
    98 4Runner Limited 4X4 e-locker :-)
    99 4Runner springs all around: 1" over factory.
    Hey Everyone,
    I just got a set of 3" Pro Comp lift coils. Bought em used and I know they aren't the best. The are better than my spacer lift though. I was just wondering if there is anyone in the area who has a press that can remove them from the struts they are on. One of the PC strut lower bushings is messed up. Called procomp and they told me the coils woll fit my stock TRD billies(I'm not really interested in putting any more money into the coils). Problem I have is that I don't have, nor can I find a press strong enough too compress the PC coils. Talked to a couple of shops. Lowest price I got for the job was $60 swap from PCs to Billies if I pull off my stock coil overs. Any help would be appreciated. I'm looking to do the swap sometime on Memorial Day weekend.
  2. May 17, 2012 at 7:52 PM
    mirraman
    Tim
    Ventura
  3. May 17, 2012 at 7:58 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Don't put the pro comp coils on your stock shocks. They aren't designed to be paired with such a high spring rated coils and will probably run in to problems.
  4. May 18, 2012 at 1:10 PM
    mirraman
    Tim
    Ventura
    Do you think I should just buy one PC shock to replace the bad one? Seller told me they only have 15K on em.
