Need Towing Advice, 5500 camping trailer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by new to colorado soon, Mar 25, 2019.
  1. Mar 25, 2019 at 2:25 PM
    new to colorado soon [OP] New Member
    Charlie
    looking to buy one
    none yet
    I am considering using a new Tacoma (V-6, manual transmission) to tow a 5500 lb camping trailer (27 ft long, 10 ft high). I will soon live in Colorado. Is this nuts? If you've towed or tow a similar load with a Tacoma, please give me your thoughts on this. Thanks!
  2. Mar 25, 2019 at 2:27 PM
    here4cake
    here4cake Well-Known Member
    Absolutely. Expect a top speed of 8MPH, a fuel economy of roughly 0.1MPG, and the most miserable driving experience imaginable.
    rando451, lynyrd3, medic2230 and 5 others like this.
  3. Mar 25, 2019 at 2:29 PM
    CarverLB
    CarverLB Who Dat?!
    Bryan
    Long Beach, Mississippi
    2021 Trd Sport 4x4
    Yes, that is nuts.
    lynyrd3 likes this.
  4. Mar 25, 2019 at 2:30 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    That would be better done with a full size truck.
    lynyrd3 and shakerhood like this.
  5. Mar 25, 2019 at 2:32 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    What they said.
  6. Mar 25, 2019 at 2:32 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    That won't weigh 5500 pounds after you load it.
  7. Mar 25, 2019 at 2:32 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    That's asking a lot out of the little truck. Other people will post screenshots of the manual and do the math on load limits... But Colorado has lots of mountains... and I'm pretty sure the wind would whip you around like you were nothing.
  8. Mar 25, 2019 at 2:35 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    I'll be that guy... It's within spec, and with the manual you actually have better stock gears for towing than most of us auto guys. You will be in third gear a lot though.
    Dubiousveracity likes this.
  9. Mar 25, 2019 at 2:38 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I'd agree with MT advantage......but that size trailer is gonna be pushing the truck around a bunch.
    I'd vote get the MT and get a smaller trailer :D
    shakerhood likes this.
  10. Mar 25, 2019 at 3:31 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Or MT and a bigger truck for that trailer!
    doublethebass likes this.
  11. Mar 25, 2019 at 3:33 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Your truck is about 2000 pounds too lite to tow something that big...all you need a 15 knot crosswind and you’ll be on your side.
  12. Mar 25, 2019 at 3:39 PM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Not on a bet. Not that long.
    Boghog1 likes this.
  13. Mar 25, 2019 at 3:44 PM
    Charlie
    looking to buy one
    none yet
    Thanks, people! I currently have a toy hauler, 30 ft and 12 ft high, but I tow it with a Sierra Denali HD Duramax and so I am spoiled. I plan to downsize both, but how far … ? I wonder now whether a Land Cruiser could tow the smaller trailer - it is significantly heavier than a Tacoma.
  14. Mar 25, 2019 at 3:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I've done it many times. The truck does not like it one bit and mine was a manual trans too. I traded for a Tundra for this exact reason.
  15. Mar 25, 2019 at 3:51 PM
    Shellshock
    Iowa
    I've towed 3500 lbs all over the country with my tacoma and its been fine. I've got a 7x14 haulmark trailer and had a camper trailer for a while too.
    If you were in the flat midwest, it wouldn't be that big of a deal but 5500 lbs down the mountain passes in Colorado isn't going to be a lot of fun. Engine braking on these trucks leaves a lot to be desired. Also keep in mind theres only a 21 gallon fuel tank, so when towing I'm stopping about every 200 miles for fuel.
    Also 27 foot is a huge trailer behind the tacoma.
  16. Mar 25, 2019 at 3:52 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    If your towing 5.5K it will do it without issue. It's the length that's going to be an issue. A good crosswind and you will have a problem. I tow a 2018 Freedom Express that's about 22' long and comes in around 5.2K. No issues and cruise in 5th gear most of the time and sometimes 6th is doable (M6 trans).
    TacoManOne likes this.
  17. Mar 25, 2019 at 3:56 PM
    dpippel
    Phoenix, AZ
    In the Rockies?
  18. Mar 25, 2019 at 4:00 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  19. Mar 25, 2019 at 4:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Technically possible, but I wouldn't do it at high elevation on a regular basis. There are several factors that come into play here. Your engine loses 3% of it's power for every 1000' above sea level. Lots of mountain passes over 10,000 ft. in CO. You'll only be working with about 70% of your engines available power.
    Most of these trucks are rated to tow 6500 lbs, but that assumes only a skinny driver in the truck with no other passengers or cargo inside the truck. You also have to consider the trucks rated payload which is about 1200 lbs. It varies by individual trucks so you need to check the sticker on the drivers door jamb. A 5500 lb trailer with a WDH is going to put about 800 lbs on the tongue. That only leaves about 400 lbs for yourself, passengers inside the truck and cargo. Most people can't make that work.
    It's not that the truck can't pull the weight. I think it can, even in mountains. It just won't do it very fast and the stress if done regularly would cause premature wear to the engine and transmission. Especially an automatic. You'll really have to watch transmission temps to prevent overheating. The bigger problem is payload which realistically limits these trucks to 4000-4500 lbs. If you had a 4000 lb trailer you could get by without a WDH and only have about 500 lbs on the hitch. This would leave you about 700 lbs available payload in the truck for passengers and cargo. Much more realistic than the 400 you'd have with a 5500 lb trailer.
  20. Mar 25, 2019 at 4:22 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    This. I'd bet that actual towing weight is quite a bit more.
