Need Trans Ratio & Axle Ratio
Discussion in 'Technical Chat' started by conservative1911, Jan 12, 2012.
  1. Jan 12, 2012 at 12:40 PM
    conservative1911
    conservative1911 [OP] New Member
    Need Trans & Axle Ratio for my 2010 Taco 4WD Acess with 4 Speed Auto / Overdrive.
    I need this info for court ref formulas regarding tire size & speed. Day after I installed Hercules Terra Trac 265x75x16 (one size over stock 245x75x16) got stopped for 54 mph in 45. I was coasting from 65 mph zone into 45 and was reading approximately hair under 50 mph.
  2. Jan 12, 2012 at 12:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Your speedo is going to be about 4% off. So, if you are going at an indicated 60 MPH, your actual speed could be 62/63 mph
