Need transmission advice
Discussion in 'General Automotive' started by Mskwared, Aug 16, 2011.
  1. Aug 16, 2011 at 8:13 PM
    Mskwared
    Mskwared [OP] Well-Known Member
    My gf cant afford a new car and i think her transmission is going out. When it gets to third gear it hesitates shifting and it wont shift until you let off the gas. I checked the fluid level and it was high (too high it seemed). Anyways what i was wondering is how hard is it to replace a transaxle / transmission? I checked pick and pull and their pricing said like $140 for one. I dont think i even wanna try and open it up, i think itd be easier to just replace it.
    Pops also said it might be the torque converter but i dont know seeing as ive never messed with a transmission.
    Advice?
  2. Aug 16, 2011 at 8:15 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    the band could need adjustment, take it to a reputable mom and pop trans shop if you have one?
  3. Aug 16, 2011 at 8:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    First........I would add some seafoam transmission additive,and drive it around then do a drain and fill and see what the shifts are like. If it helps it........it will be around $30.....seafoam and tyranny fluid together. Cheaper and easiest way to start.
  4. Aug 16, 2011 at 8:46 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    agreed, ive also used lucas, just dont add brake fluid to it, i repeat do not
  5. Aug 16, 2011 at 9:22 PM
    Mskwared
    93 camry 4cyl automatic. Had 300k miles on it and her dad put a 200k mile used motor in it. I think its the original transmission though. Im not surprised its giving out but she needs to squeeze a couple more months at least out of it. Im sure they replaced the head gasket while they were in there but she still burns oil im thinking because the car smokes whenever she starts it.
  6. Sep 10, 2011 at 8:16 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sounds like it's clapped out. If it's not slipping, it will probably last another couple months doing nothing. If she wants to keep it, it's worth letting a trans shop look at it. Might be something cheap to fix. Reminds me of symptoms of a bad vacuum modulator on an old car. I am thinking a solenoid perhaps on yours.
