Need Upper control arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coolandrew0, Jul 8, 2025 at 1:50 PM.
  1. Jul 8, 2025 at 1:50 PM
    coolandrew0
    coolandrew0 [OP] Member
    Andrew
    Looking for new upper control arms I have a 3.5in lift currently have the rough country control arms been blowing through balljoints every 4 months or so. I do off-road pretty regularly with my truck. seeing what’s out there getting tired of replacing balljoints. my lower TTX have been in the truck for over 120k with zero issues
  2. Jul 8, 2025 at 4:48 PM
    GotExhaust
    GotExhaust Well-Known Member Vendor
    Nick
    Hi, we can offer Freedom Offroad UCA's. We have them with a standard ball joint as well as an option that has a uniball for better articulation and durability. They are both for 2-4" of lift over stock.
    We also can offer Core 4x4 adjustable UCA's
    Message me if you would like a quote.
    Rob MacRuger likes this.
  3. Jul 8, 2025 at 5:41 PM
    Danke5305
    Danke5305 Well-Known Member
    2013 tacoma prerunner
    I run dirt king uniball heim but its over kill to be honest with no issue other than the few times i sent my wheel into the fender.
  4. Jul 8, 2025 at 6:19 PM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    I have some spc ones they have worked for me so far.
  5. Jul 9, 2025 at 7:41 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    3.5" is way too high. I suspect you'll have problems with ball joints no matter what UCAs you get. At that height just about any ball joint will be at their max range of motion. Either lower it down to at least 2.5", or look into drop bracket lifts.
    ZColorado and GilbertOz like this.
  6. Jul 9, 2025 at 1:23 PM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    Dirt King works for well for me. I'm at 2.5+ in. suspension lift. I do not have caps that cover the joint/zerk.
  7. Jul 10, 2025 at 5:11 PM
    coolandrew0
    Andrew
    Wanted to go as high as I could without a drop bracket as I didn’t want it to get caught up in the snow
  8. Jul 10, 2025 at 6:22 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    At that height you will have non-stop problems. You probably have zero down travel, and your CVs are probably maxed. You likely need a drop bracket lift to lift that high.
