need wheel advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma2nd, Feb 24, 2011.
  1. Feb 24, 2011 at 5:56 PM
    Tacoma2nd
    Tacoma2nd [OP] Active Member
    06 prerunner
    2.5 inch coil spacer and rear add-a-leaf
  2. Feb 24, 2011 at 6:01 PM
    Hondarider08
    Hondarider08 "That's what she said..."
    Justin
    Logan, UT (Originally Pocatello, ID)
    05 Tacoma TRD
    Leveling kit, K&N drop in, and a Loud Ass Stereo :)
    It depends on the backspacing. I'm not an expert but i'm pretty sure a 17'' wont rub on calipers. If you're doing a 285 tire, you're going to want to go with at least a 4.5'' backspacing, otherwise you're going to have problems with rubbing on cab mounts. I couldn't find specs on website, if you find anything else let me know.
  3. Feb 24, 2011 at 6:05 PM
    Tacoma2nd
    06 prerunner
  4. Feb 24, 2011 at 10:12 PM
    Hondarider08
    Justin
    05 Tacoma TRD
  5. Feb 24, 2011 at 10:18 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah +25 offset and 6" backspacing: The tires gonna hit the UCA for sure. Doubt you'll even be able to get them fully into position on the hub.
    If you want a 17x9 rim, look for a 0mm or -6mm offset, and 4.25" backspacing.
  6. Feb 27, 2011 at 5:36 PM
    Tacoma2nd
    06 prerunner
    thanks guys
  7. Feb 27, 2011 at 5:42 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    For a 9" rim, -12mm offset is 4.5" backspacing, and -18mm offset is 4.25" backspacing.
    -6 mm would be 4.75" backspacing.
  8. Feb 27, 2011 at 6:18 PM
    Tacoma2nd
    06 prerunner
    what about some 17x8.5 rims have a -6mm offset and a 4.5" backspacing? will they work without rubbing the UCA?
  9. Feb 27, 2011 at 6:20 PM
    KPT
    09 Prerunner
    If they have -6mm offset and 4.5" backspacing then they must be 8.5" wide rims....
    If that is the case, then all the numbers are consistent with each other, and you are good to go without rubbing the uca with that setup.
  10. Feb 27, 2011 at 6:24 PM
    Tacoma2nd
    06 prerunner
    thank you so much for that information. honestly ive been doing so much research.
