Need wheel help with a 5 lugger
Discussion in 'Wheels & Tires' started by xagent, Oct 8, 2017.
  1. Oct 8, 2017 at 1:40 PM
    xagent
    xagent [OP] New Member
    I have a 1996 2wd ext cab 4cyl that has 215/70R14 6JJx14 ET38 5x114.3 M12 x 1.5 cb=67.1. All of the steel rims have some bending which made balancing them 10 years ago difficult. It's got all season BFG long trial tires on it and I will have to change them out by this summer. It's kind of an extra vehicle mostly used for hauling, chores, etc. I was thinking of some jeep rims in either 15 or 16" and want know if they will work. I will have to use some new lugnuts going to alloy and use center wheel spacers and I have seen some that might work.
    One is off a 98 cherokee:
    225/75R15 7Jx15 ET20 5x114.3 1/2" - 20 UNF CB=71.5 or
    215/75SR15 7Jx15 ET25.4 5x114.3 1/2" - 20 UNF cb=71.5
    I've seen some 16' that might work. I was recommended a 15 inch because of the higher sidewalls but 16 might fit and is more common. Will I have a fit issue or offset issue with the Jeep stuff?
  2. Oct 8, 2017 at 1:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    We have a 5 lug forum. You'll find some helpful info there.
    You are on the right path knowing dimensions and such. It is the centerbore that makes it difficult.
