need wiring advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12taco12, Aug 2, 2020.
  1. Aug 2, 2020 at 2:06 PM
    12taco12
    12taco12 [OP] Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    so i have this coleman power chill cooler thing. it runs off 12v or 110v. i have the 110v in my txpro bed but want to add a 12v outlet
    i was thinking i can use this
    https://www.amazon.com/Converter-Tr...HA6ZF44GDSA&psc=1&refRID=ZHJSVQCC2HA6ZF44GDSA
    or i want to wire an actual 12v cigarette style outlet in the bed. i have seen many do it and i know i should run a power wire from the battery to the back i plan on really only running that currently for trips so im thinking i can get away with a switch like this
    https://www.amazon.com/gp/product/B07WVQ4NKD/ref=ox_sc_act_title_1?smid=A2F06A1DTVXHL7&psc=1
    and since it has an inline fuse and a switch that i can turn off when not in use i won't need to add a fuse block
    any insight peoplesssss
  2. Aug 2, 2020 at 2:25 PM
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    You need to check the draw (amps / watts) for AC & DC of the Coleman deeding on which was you want to go ac>dc / dc>ac
  3. Aug 2, 2020 at 2:26 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Determine the power the “cooler thing” draws. It will be in amps and or watts. If the converter, wire and fuse is under the cooler max draw then That is 50% of the issue.
    It sound like you intend to take power off the 110v power in the bed, check its max power rating. I have an OEM 110v bed outlet and it’s rated at something like 400 watts max with engine running. Its good for charging an iPhone or an emergency light. It is not like your home 110v outlet; i.e., it cannot run a hairdryer.
    HPMaster likes this.
  4. Aug 2, 2020 at 2:27 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    The converter will work but it's a crap way to go about it. You have a 12v DC system that is being converted to 110v AC for that outlet. Then you are converting it back to 12v. Lots of power loss.
    Your panel is a much better idea and several people here have gone that route. I don't know anything about that particular manufacturer though. There are a couple of threads on the mod.
  5. Aug 2, 2020 at 3:01 PM
    12taco12
    rochester NY
    2012 TX Pro
    I've read about adding a 12v on the bed in the cubby or above the 110v. im thinking just adding 12v but i DONT want to add a fuse block for one outlet in the bed. that 12voutlet combo in the link has an inline fuse. wouldn't that inline fuse be enough??
    the manual says POWER REQUIRMENTS: 9.5 to 14.4 volts DC, 4 amps @12v DC nominal
  6. Aug 2, 2020 at 3:46 PM
    12taco12
    rochester NY
    2012 TX Pro
    bump with the new info de-gens
  7. Aug 2, 2020 at 3:54 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
  8. Aug 2, 2020 at 5:16 PM
    tonyl13
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    If you are going to run it on DC (good choice like said converting back& forth wast power)
    If you run #14 stranded wire from the battery withe a 7.5A in line fuse at the battery end and keep the length of the wire under 16' you should be fine
    I would not recommend a auto reset type fuse for this app. it could cause a fire
  9. Aug 2, 2020 at 5:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The first one RoyPow is only rated at 2A.
    If your cooler says it needs 4A, that one won’t work.
    The second one with the switch, says it is 10A.
  10. Aug 2, 2020 at 5:30 PM
    12taco12
    rochester NY
    2012 TX Pro
    so go with the switch i want but replace the 10amp fuse with with an inline blade fuse of 7.5 amps near the battery ?
  11. Aug 2, 2020 at 5:43 PM
    tonyl13
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Sorry I guess I missed something what switch?
    It would help a lot if you draw a diagram / schematic
  12. Aug 2, 2020 at 5:48 PM
    tonyl13
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Down for the night, wild land fire on call
    TnShooter likes this.
  13. Aug 2, 2020 at 5:50 PM
    TnShooter
    Deogee
    STOCK
    Keep safe buddy.:fingerscrossed:
    Hope you all get it out quickly.
  14. Aug 3, 2020 at 2:08 AM
    12taco12
    rochester NY
    2012 TX Pro
    speaking of the Amazon switch in the main post
